URGENT HELP PLEASE - GEARBOX
Started by Anonymous, August 4, 2008, 22:50
I think you're right Liz, private sellers escape most comebacks. I've been caught myself in the past, but who knows, a person with a conscience may exist and I have my fingers crossed for the OP that their seller is one.
StuM
There is some good reading [Admin] Link removed upon the request of the company targeted [/Admin] regarding your rights when buying from a private seller.
Stu
Stu M
Quote from: "SimonC_Here"
Quote from: "DeeJ"The car is not at all down on power
Have you driven any other MR2's to compare it against?
Simon
No, but my dad use to have an mx-5 1.8 and it feels more powerful than that, and my dad has drove it and he said it doesn't at all feel down on power.
I am taking it to my local garage tomorrow, and they are going to see if they can tell what the noise is.
Also I will be going to my local toyota garage to try and get someone from there to listen to the noise aswell.
Another quick question,
If the car had been sitting for a couple of months without being properly run, could this affect the car.
Quote from: "DeeJ"
Simon
not really a good comparison
Quote from: "DeeJ"Another quick question,
shouldn't do
StuM
Only thing I would expect is the brakes to be a bit noisy where the disks have a build up of corrosion.  Certainly wouldn't expect odd gearbox noises and would not explain the lack of oil.
Do you know what Toyota garage did the manifold?  As it was only in April, they should be able to tell you why it was done and if anything else was changed at the time.
Stu
Stu M
I know what garage did the change, I will ring them tomorrow and enquire about it.
But atm the oil is not worrying me its just the gearbox.
Does anyone know how much a new or recon gearbox is fitted.
Quote from: "StuM"
Stu
The exhaust manifold was replaced at a cost of £405.48, the exhaust at a cost of £383.25, and a clutch kit was fitted all in one go in April
StuM
Quote from: "DeeJ"Does anyone know how much a new or recon gearbox is fitted.
This was posted earlier today:
Clicky
Quote from: "DeeJ"But atm the oil is not worrying me its just the gearbox.
I would be reluctant to start spending any money on it until you know:
a) Why there was no engine oil in it.
b) What the sellers response is to your concerns.
Cheers,
Stu
Stu M
Tenner says the gearbox is fine and your engine is b0rked. Pre-cats gone is why your manifold and exhaust were changed (when it should have been the main cat replaced as well).
Change the gearbox if you want, but I'd be shopping for a new engine first.
Quote from: "Ekona"Tenner says the gearbox is fine and your engine is b0rked. Pre-cats gone is why your manifold and exhaust were changed (when it should have been the main cat replaced as well).
But the engine pulls great,
Definetely 0-60 in sub 8 secs.
No loss through the rev range.
So I can't see the engine being knackered
rather depends on how much oil it's drinking
that cost for the manifold is half what it costs a dealer
i.e toyota manifold is £700 plu s vat
add on their markup plus labour
if they did it for that price it was a goodwill gesture, which again implies they know something
Liz
Quote from: "DeeJ"But atm the oil is not worrying me.
I think it should be your main worry, your car has been previously repaired for an engine failure, probably not had the main cat replaced and has now no oil in it.  I am prepared like the rest of us to stand corrected on this - but I will give you good odds that its your engine making the noise and not the gearbox.
In fact if it is the gearbox and you give me proof of that I will chuck a tenner in the club funds!
Still.... last I am saying on the matter, there are people on here with more knowledge than me.  Good luck.
Would it worry you if you had no blood in your body?
Trust the advice you are getting here, your engine is most probably fubar, forget about the gearbox and concentrate on trying to get your money back. Good luck.
Seen my local mecahnic today, he knows about the pre-cat failure, and he said that the engine is fine.
His only concern is about the gearbox - just shopping around for one now. Toyota want roughly £2000 fitted
StuM
#41
Quote from: "DeeJ"Seen my local mecahnic today, he knows about the pre-cat failure, and he said that the engine is fine.
Sounds like you got very lucky with that bit then - even if the precats hadn't failed, driving the car with no engine oil would destroy it.
Keep an eye out for 6 speed boxes as well - you could at least get a silver lining to the cloud if you upgraded to that.
Stu M
muffdan
#42
I hope your mechanic is right, but I don't think you'll know if your engine is fine until you've driven 500 miles. Keep a very close eye on your oil consumption, check every 200 until you know what it's using. The sump was empty for a reason!
based on what? looking at it?
I saw your link to the Autotrader ad, which may help your cause, but I am no solicitor.
One thing I am confident of though, this car is going to cost you serious money if you hang onto it, judging from what you have reported so far. The gearbox sounds like the tip of the iceberg and I know we've said it before, but put your maximum effort into returning it to the seller and getting reimbursed, its the most sensible thing you could do.
All the signs point to more than one problem, and this will hurt your wallet.
I symapthise, but this is what I would be focussing on.
The above is good advice, the car has by your own admission been driven with no oil in it. Even if your gearbox is the problem at the moment it is highly likely that your engine will be fubar shortly. Put all your efforts into getting your money back, i would not under any circumstances spend money on the gearbox at the moment.
