6 speed gearbox
Started by ad_car_08, September 14, 2008, 18:28
ad_car_08
Hi,
I couldn't find anything regarding my query using the search, so I'm hoping you guys can help.
Is it possible to buy a 6speed gearbox & bolt it straight onto the engine in place of an original 5speed??
[/size]
Easy answer is yes. I think you'll need a facelift shifter to go with it though, but stand to be corrected.
Hi,
Is the six speed box got the same ratio of the 5 speed box at the 5th/6th gears or is there better fuel efficiency with the 6 speed on the motorway. Is it a stronger gearbox if you were going to fit a turbo or is it just Mr T joining the 6th gear market. Have a six speed box on my x-trail 5th is a waist of time 4th to 6th is the usual for me. I would change my 2`s for a good reason.
Bob
1st to fifth are the same ratios, with 6th as a longer cruising gear. The 6 speed is no stronger than the 5, weighs a tad more and is about 25mm or so longer, but apart from that not much in it.
I have a standard 6 speed shifting cage if you need it (for a small consideration   s:wink: :wink: s:wink:  )
Is this reverse vulturing?  s:lol: :lol: s:lol:
*vultured*
He swoops, he scores   s:wink: :wink: s:wink:
Don't think it's quite that simple with an SMT. (Quite expensive I guess?? ecu as well; how do you get '6' to come up on the spedo etc, etc).
SteveJ
Quote from: "sandstrain"Don't think it's quite that simple with an SMT. (Quite expensive I guess?? ecu as well; how do you get '6' to come up on the spedo etc, etc).
The '6' would be the easy bit, the difficult stuff would be the replacement ABS pump to do the traction / stability control, the TC/SC ECU and sensors and the new wiring loom(s)
Probably take that as a no on the SMT then   s:lol: :lol: s:lol:
the reverse on the SMT was done in the US
oh and you dont need a shifter cage to go from a 5 to a 6 speed, sorry Ste but they fit fine, we did it on Marks with no issues at all
I think the shifter cage issue is only with some short shifters.
I have the 5spd cage and B&M/Che/knockoff shifter working fine (notchy as hell, but fine as long as you don't want to change gear in a hurry!)
ad_car_08
So, cutting straight to the point...you say it is possible to buy a 6speed MK3 MR2 gearbox off the shelf (or scrappy..wherever), and bolt it straight on, no problems?
The only extras you'd need are a replacement gear knob to remind you, you have 6 gears?!   s:bounce: :bounce: s:bounce:
[/size]
correct done it many times
ad_car_08
Quote from: "markiii"correct done it many times
Excellent!
I'm still fairly new to this forum, and have been reading a few topics which have given me the impression you really know your stuff markiii.
In your honest opinion, are there actually any gains to be had from fitting a 6 speed box to an engine which was running a 5 speed?
I'm not terribly technically minded, but if I had to comment, I'd say that the extra gear would drop engine revs when cruising at 60/70mph, making the car slightly more fuel efficient if you travel on motorways/dual carriageways the majority of your journey?
Or if your giving it beans, an extra gear would get the car to top speed faster, rather than waiting for the revs to climb & peak in 5th??
Is there more to it than that or have I got something right for a change?!   s:lol: :lol: s:lol:
[/size]
think of teh 6 speed as a 5 speed with a cruising gear added at the top
other than motorways your unlikely to see any improvement (your acceleration will actually be worse due to teh extra weight, though I doubt thats noticeable)
the only improvement will be lower rpm at cruise and hence slightly better fuel economy.
top speed is actually better in 5th.
however 6th is really not a gear in which to expect much oomph, unless you have a turbo, so even at motorway speeds expect to downchange to overtake.
if it were me, I'd go 6 speed if my box died, but other than that not really worth teh effort or cost.
however if you do go with it, I suggest you do teh clutch and flywheel whilst your in there, as your already paying teh labour.
ad_car_08
In that case, I could probably spend the money I'd invest in a 6'box, more wisely. On what, I'm not sure as I'm running a totally stock setup so far!
   s:bowdown: :bowdown: s:bowdown:  Thank you for your advice!    s:D :D s:D
[/size]
