Stage 4 Turbo Setup
Started by muffdan, October 1, 2008, 00:58
I'd be slightly concerned where teh chipped missing bits went?
muffdan
Quote from: "markiii"I'd be slightly concerned where the chipped missing bits went?
Hopefully into my old engine   s:shock: :shock: s:shock:
muffdan
Update:
The turbo's back on and the smoke gone, but not much more power yet.
The problem now seems to be my cheapo AEM Truboost boost controller. I'll be replacing it with a Profec E-01 next week and then, hopefully I'll see some bigger bhp numbers.
Encouragingly during the latest mapping session my turbo produced 17 PSI at 6800 on the dyno, so it sounds to me like the turbo is big enough to push the air needed to produce the 300+ bhp I'm looking for (unless I'm not understaning something?). To get this high end boost level though it was producing big PSI @ 3800 which didn't make for a good torque curve or look good for my engine in the long term. With the variable boost control available through the E-01 we should be able to create a flatter torque curve to give the high end boost without the mid range peak.
Anyone got an E-01 for sale?!
northernalex
Well that sounds like some really good news! Great to hear that youre one step closer to the big numbers!
evileye_xc said:
Jason, dont forget the 80+ BHP increase from the Kirks install tomorrow!!
Its getting there Jason, you must be just a whisker away from the goal now.
Great stuff mate.  s8) 8) s8)
muffdan
Quote from: "uktotty"Jason, dont forget the 80+ BHP increase from the Kirks install tomorrow!!
lol, I'm going to have to learn to live with any vibration I get from the Kirks no matter what I think. Mark at Rapid GB told me my engine twists significantly on the stock mounts when on full throttle.
As a future upgrade, you could always go for bigger torque mounts like I have, basically Mk2 turbo size, still silicone inserts, but no twist at all.
evileye_wrx
Phil
muffdan
Quote from: "evileye_xc"Or one of these  m http://www.neweraparts.com/Default.aspx ... ductID=795 m
That looks pretty interesting. Anyone actually used one of these?
DannyN
FGRob has one (that he bought from Phil) and it attaches to his C-One rear strut brace.
Rob will be along to correct me but I'm pretty sure that Rob had the bearings within the damper replaced and upgraded.  But once this had been done he is very happy with it and its performance
[/size]
Quote from: "DannyN"FGRob has one (that he bought from Phil) and it attaches to his C-One rear strut brace.
Yep once the bearing were replaced no real problems - just gives a bit more cam noise especially over 4500rpm - Love it.
Here's the thread with all the details and photo's :  l viewtopic.php?f=7&t=20759&hilit=damper l
Rob
muffdan
Two pieces of news.
I got the Kirks in yesterday (cheers for the hand roger) and I am more than happy with the levels of noise and vibration. It's really only uncomfortable when pulling at low rpms, around 1500 which I tend to only do when rolling out of a junction in second gear or the likes. That's the good news.
The bad news is cylinder 3 has given up today. Continuous misfire (flashing cel) and plumes of blue smoke out the back. It sounds very unhealthy, clearly only running on 3 cylinders. Too early to know what has gone wrong and why at the moment!
Very upset about this at the moment as I have spent a lot of time and money on the best internals and rebuild with this engine over the last 6 months. I'll have to get it onto a flat bed and over to SP so Matt can figure out the details some time this week or next.
Bad times   s:( :( s:(
Really really sad new Jason, I am sure you have a case tho, its not as if you did all the upgrades yourself.
See what SP say about the issue and see how soon they can fix it with no charge!
Gutted for you Jason, I'm sure Matt will get to the bottom of it for you.
#40
Sad to hear that Jason - definitely let us know what happened to cylinder 3, please? Pictures would be great - I'm afraid I'd be expecting a collapsed ring land given your description (and knowledge of what kind of boost you were pushing etc).. not good.
Fingers crossed the bore is OK, if that's the case.
DAMN!!!
That's a rough deal Jason   s:( :( s:(
Please don't give up though, we're really looking forwards to next years road trip  s:wink: :wink: s:wink:
Les
muffdan
#42
Quote from: "Les"Please don't give up though, we're really looking forwards to next years road trip  s:wink: :wink: s:wink:
Les
Considering this project has been running since June and I'm now probably worse off than when I started, the May road trip is probably a realistic and sensible target to aim for getting it fixed! I'm not feeling much love for the car at the moment but hoping it will pass over the next couple of weeks.
I've got a busy December with Christmas and Adele dropping out our second baby some time in the next week or so. I think I'll get the car up to SP and let Matt strip it down and investigated what's gone wrong on his back burner. Hopefully he can identify a cause too. I'll then make a big push in the new year to get it going again.
What is annoying is that the setup has only been mapped to 230 bhp and ~270 lb/f of torque. The internals should have had no problem what so ever at those levels. I suspect there's been a mistake made somewhere along the line. Be it in the manufacturing of the parts, the machine work fitting the sleeves, the machine work on the head, the assembly of the engine or the mapping. With four different companies involved in this rebuild, am I going to be able to assign 100% blame to one of the parties and is it fair to them to try to? Probably not. I fear I'm going to be footing the bill for this.
I certainly know how you feel, its a major disappointment when it doesn't work exactly as you hoped it would. I've had similar trials along the way as well. We need to encourage each other in things like this, and I'm sure you'll get it sorted and it will be fantastic when its all done.
Mici
#44
I'm so happy our car is SMT so it won't be überfast with turbo kit anyway, that is what is keeping me away from boost right now. Well, that plus money factor and the fact that I only have driven the car like 2 km's. All this being said, I have "some" experience on what aftermarket/home brew boost is, I have boosted my MX6 V6 with pretty decent power figures. This car btw has been standing in garage for over 3 years now after the last incidence of feeling the need for more power, turbo swap and Link+ ems installation etc etc... All of this and the car still is FWD.   s:cry: :cry: s:cry:
I guess I only have to take a ride in Tem's car to understand what my future will be.   s:D :D s:D   I'm soooo trying to stay away from that!   s:bounce: :bounce: s:bounce:
If I would, I think the TTE would pretty much be the one to get as it seems to be the only one that could be legal here.
Have a good time boosting and don't break anything up.
Mici
TTE on an smt won;t be slow by any means, drop a lightened flywheel in there and it wil love it  :-) :-) :-)
#46
Quote from: "markiii"TTE on an smt won;t be slow by any means, drop a lightened flywheel in there and it wil love it  :-) :-) :-)
Mici, you heard what he said, just do it.  s:P :P s:P
Mici
#47
My wallet is already whining about buying the car. Yet, the boost is addicting and I've had some, so it is very, very hard to keep away from it, even if the car will be for my GF.   s:crazyeyes: :crazyeyes: s:crazyeyes:
#48
Quote from: "Mici"even if the car will be for my GF.   s:crazyeyes: :crazyeyes: s:crazyeyes:
I've heard that even girls can drive a TTE turbo, right Liz?  s:D :D s:D
Chris
#49
Hmm, so I could by the ttet in the for sale section and have two turbo'd beasts!!   s:D :D s:D
[size=100]
Ex 2003 Astral Black 6sp SMT
Ex 2002 Lagoon Blue 5sp MT
[/size]
