What should my compression be?
Started by Anonymous, November 4, 2008, 16:54
Used my mates compression tester ealier and I got readings of 170psi from my cylinders.
It was exactly the same for all the cylinders, is this OK.
Also found my spark plugs to have a huge gap, so will be replacing the plugs tomorrow.
from meory it's anywhere between 170psi and 220psi so on teh low side, but of they are all with 15 psi of each other it's just in spec
