Damn car won't start, started and then wouldn't start again
Started by Ilogik, January 12, 2009, 08:47
Ilogik
Pulled the car out the garage this morning to go to college, started up fine, with no hesitation. Turned it off to shut the garage door and when i went to start it again it just wouldn't turn over, like it had a flat battery.  Just waiting on the RAC to come out,  worried now as if the battery was flat surly it shouldn't of started up first time.
I used the search function but couldn't find any results with that, any known issues with this?
Ex: TRD stage 1 TTE Turbo
Rowland
Dodgy or loose earth at the battery terminal?
  s:? :? s:?
StuM
Are all the connections to the battery nice and tight?  It the ground connection ok?
Stu M
Ilogik
all seemed fine when I checked, dash lights all come up normally like they did before. They all go dim when you turn it over.
The earth should run off on the passenger side onto the chassis shouldn't it?
Ilogik
if the alternator is gone, what lights come up?
SimonC_Here
How about:
Battery is a little flat (for whatever reason)
You start it the first time, taking a chunk of charge out.
The second time you try the battery no longer has enough charge.
How far is your trip to collage? If it's only short, the altinator might not have enough time to top the battery up fully.
Simon
Liz
Enough petrol?
Ilogik
Quote from: "SimonC_Here"How about:
Simon
college is 9 miles away,  rac man is taking his time  s:( :( s:(  Hopefully nothing to serious.  As for petrol I have over 1/4 of  atank, but its defiantly battery related. Wondering if its something to do with my alarm draining it, as when removing the kep it makes a beep, which it never usually does.
Could also be an iffy starter motor
Ilogik
Simon
Only other thing i can think would of caused it would be that i touched something when I was fitting the new steering wheel, have done this job many times before on different cars, and surly to be draining power the horn would have to be stuck on.
Had a truck with a similar problem, turn the key to start and the lights would dim as per a flat battery, the batteries tested ok as did the alternator and earth connections, sometimes it would start without a hitch, it was found to be a fault in the pre-engage solenoid on the starter motor.
A fuse?
IGN2
alancdavis
Simon
I would go with this reason,,,,,,,,,the same thing happend to me,,,,,,,,gave the batt a good overnight charge and this cured the problem
Red Calipers with DBA Cross Drilled and Grooved Discs,,,,2005 Red and Black Leather Custom Seats,,,,,TSW,17ins Wheels,,,,,2003 colour coded side vents and rear bumoer inserts,,,,Custom rear bumper skirt,,,TTE Twin Rear Pipes,,,,,,TTE Front Bumper,,,,,Red and Black Steering Wheel,,,,,Blitz Induction Kit,,,,,TTE Style Bar,,,,,Goodridge Stainless Braided Hoses,,,,,,,,,Front and Rear Strut Braces,,,,,,Rear spoiler
Liz
Batteries are cheap for this car though - about £33 is your worst case scenario.
Rowland
Quote from: "Liz"Batteries are cheap for this car though - about £33 is your worst case scenario.
That sounds unusually cheap.
I paid £50'ish for a new Toyota battery not so long ago.
Liz
Thats what I paid for mine about 10 months ago. Maybe now realised it was dirt cheap and changed it, I even queried it when they told me the price.
StuM
Quote from: "Les"Had a truck with a similar problem, turn the key to start and the lights would dim as per a flat battery, the batteries tested ok as did the alternator and earth connections, sometimes it would start without a hitch, it was found to be a fault in the pre-engage solenoid on the starter motor.
Used to have an old Renault that did this.  If you took handbrake off and put the car in gear, then rocked it back and forth, then tried to start it often would - guess the starter worked in one position and not another.  Probably no good on an HGV  s:shock: :shock: s:shock:  but might be worth a go here.
Also.. do you hear anything when you turn the key - clicking etc?  Does it turn over at all, or is it totally dead?
Stu M
BlackSabel
If all lights come on as normal but engine don't trun It sound like your starter motor is jammed?
BlackSabel 2003 , Leather interior, TTE Twin Exhaust, Hard Top, Precats gutted, Dev's Keyhole cover, Jspec Black Nose Badge, Apexi Induction Kit, TTE Banana Spoiler, Rear Spats, Toyo TR1's Proxes, Silver Calipers with SteveJ 'MR2' decals, Cusco front strut brace, trd Short Shifter, Speedsource bushings. Mongos with spyder decals. 7" touch screen double din.
philster_d
Aarons battery was about 68 quid before halfords discount brought it down under 50.
Ilogik
looks like it was a weak battery, connectors were slightly lose, drove it all the way to college after rac guy came out, who checked it over, alternator was good, the battery was charging so I think I may need to replace the battery. If this is the case, I think i may upgrade to a 6kg one spotted at Autosports.
How heavy are normal bats?
ex-member
Glad you got sorted mate.....lol and the weight saving continues!
Kool PT
Quote from: "Ilogik"looks like it was a weak battery, connectors were slightly lose, drove it all the way to college after rac guy came out, who checked it over, alternator was good, the battery was charging so I think I may need to replace the battery. If this is the case, I think i may upgrade to a 6kg one spotted at Autosports.
http://www.mr2roc.org/phpBB3/viewtopic.php?f=7&t=22620&hilit=lightweight+battery some useful battery info here
I will be replacing my stock battery with an Enersys Odyssey PC545 at some point, a saving of 7.78kgs
Ilogik
Quote from: "Kool PT"
sweet so basic thing is they don't last long, will have a bit of research into it, spotted some nice light ones at Autosports, but if battery life is slashed id rather get something slightly heavier.
Saying that the battery has been good thus far.
Ilogik
damn not driven the car for about 5 days due to snow,  its dead again boo hiss, time for anew battery I think.
StuM
Quote from: "Ilogik"damn not driven the car for about 5 days due to snow,  its dead again boo hiss, time for anew battery I think.
Snap - left mine for a couple of weeks, one of which it was covered in a snow crust (although car-cover on) and it wasn't interested at all on Saturday afternoon.  It did turn over, but very slowly.  Left it on charge overnight and all fine on Sunday.
Stu M
