MR2 Roadster 2.2 Turbo... (diesel)
Started by Rogue, February 2, 2009, 13:50
Rogue
Hi All,
As some of you may know I've recently changed the plans for my MR2 Roadster and put my turbocharged BEAMS engine up for sale. Well, here's the reason:
It's a Toyota 2AD-FHV engine from a 2007 Auris. It's a 2.2 Turbo Diesel delivering around 180bhp and a smidge under 300lb/ft of torque. Now while the bhp  figure may not seem impressive, bare in mind that it's still forty horsepower up on the stock figure, and the torque figure is nearly two and a half times as much!
The initial plan is to build the car up for road use in order to shake it down, with longer term plans to cage it up and race it. Unfortunately there's no Britcar 24hr race this year, otherwise we'd go straight for race trim. Since it will be ultimately used for endurance racing, we're not planning to modify the engine significantly (except for adding external oil coolers etc if required) and we'll be keeping the stock engine management.
More engine pictures:
muffdan
VERY interesting indeed!
StuM
Definately very interesting.
What is the additional weight of the diesel engine?
Stu M
Rogue
Quote from: "StuM"What is the additional weight of the diesel engine?
We haven't weighed it yet and it certainly felt heavy trying to manoeuvre it into the back of the company battlebus. But then it is complete with gearbox and fairly unwieldy!I'll weigh it in due course, but it's an all aluminium engine just like the 1ZZ so I'm optimistic that there won't be too much of a weight penalty. The Auris donor car weighed 1510kgs!
Patrick
StuM
Thanks Patrick.  Didn't realise it was all aluminium.
That amount of torque would be incredible in the MR2 I should think.   s:D :D s:D
Stu M
Quote from: "StuM"Thanks Patrick.  Didn't realise it was all aluminium.
yeah but how high will it rev?
to have that much torque but that little power I'm guessing not very
Rogue
Quote from: "markiii"yeah but how high will it rev?
Peak torque is from 2,200rpm to 2,600rpm and peak power is at 3,600rpm but the gearing is taller so it's all relative. I'm really looking forward to experimenting!
Patrick
Ilogik
Sounds like a wicked project patrick.  Have you thought about trying out the integra engine or working with something else like a 1.8t from an audi tt? like they do in Elises?
Ex: TRD stage 1 TTE Turbo
Rogue
Quote from: "Ilogik"Sounds like a wicked project patrick.  Have you thought about trying out the integra engine or working with something else like a 1.8t from an audi tt? like they do in Elises?
Not really. We like Toyota technology, and we like the level of compatibility throughout the range! the other reason is that most race series restrict you to using an engine from the original manufacturer.
Patrick
I think it will be very interesting, and very quick midrange. With an inexpensive remap, a chunk over 200bhp should be available , with even more torque. I've often wondered what a Roadster would be like with a good TDi unit onboard, so look forward to seeing how this one turns out. Okay it may not have a rorty soundtrack, but should give a hefty shove when needed. Has the box got LSD?
tell you what Nige I like teh look of those drivveshafts, seriously beefy, wonder if tehy would fit teh v6  s;-) ;-) s;-)
Knowing Toyota, I bet they would fit. The interchangability of Toyota bits is astounding. I'd love a set of those if they did fit. Might be just the thing to withstand those highspeed gearchanges Mark.   s:wink: :wink: s:wink:
custardavenger
Oh no. The MR2 becomes a sport tractor.   s:D :D s:D   Hats off to you guys for doing it but unless it's a truck I just can't get with the concept of diesels in motorsport, It's the reason I stopped going to Le Mans.
Project Custard Clicky
I can see it being great for racing and looking forward to seeing the build thread, speaking personally though I wouldn;t want to own one as a road car
Wow, all that torque!!   s:o :o s:o
I can see the next must have accessory it will need    s:wink: :wink: s:wink:   CLICKY
Only kidding   s:lol: :lol: s:lol:
Very interesting project and look forwards to reading about its progress.
Les
Rogue
Quote from: "Les"I can see the next must have accessory it will need    s:wink: :wink: s:wink:   CLICKY
Lol! Actually, the race team already has one of these:
...which pulls the trailer that the race car will be sat on. (Wondering off-topic, but the RV is an excellent piece of kit. Just under 7.5t which means I can drive it on a car license and it has a 7.4l V8 Chevvy in it...)
Patrick
DannyN
*waits for Russ*
[/size]
Steven Velocity
I'm on the fence about this one. From an engineering standpoint this is outstanding. From a fuel economy standpoint this is still an excellent project. But from a performance roadcar standpoint I'm not so sure. In the TDI Auris I've driven the power delivery has been powerful but short lived, as in a very narrow powerband. The engine actually felt as gutless as a 1zz below 2k rpm, and then kicked like a angry roid fueled mule from 2k to about 4k, but then very noticeably petered out from 4k to the 6k (or 6.5k) redline.  Maybe gearing & tuning can fix the powerband. Also, although it may be aluminium, that's still one heavy engine/gearbox for a Roadster. Still, kudos on the project. I hope you start a build thread for us to follow. I'm looking forward to the end result.
SV
DRUM & BASS IS THE ANSWER, wobble wobble...HARD TECHNO ALL NIGHT LONG! BLOWN 2ZZ (R.I.P.) (FI project]/PFC/J&S Interceptor/complete custom 2.5" exhaust/6pd w/LSD/8lb aluminum Fidanza flywheel/ACT eXtreme clutch/TRD quickshifter/Speedsource brass shift cable bushings/BC Racing RAM coilovers/Woods slotted rotors/Hawk Pads/Saner 25.4mm front sway bar/Corky\'s BP/Kirks mounts/custom roll cage/JDM hardtop/Dev\'s KHCs/clear corner markers/150lbs added lightness/Toyo R888 for now BWAHAHAHA!!!
I doubt if the weight will be much of an issue. My roadster is one of the heavier ones at the rear end and it is perfectly manageable, a bit different, yes, but no problem.
custardavenger
Ah but you have Torque and HP and a good rev range Nige
Fair enough Rob.  s:wink: :wink: s:wink:
ChuckyBru
This is very interesting.  I'll be following your progress eagerly.
As an aside I had a quick look at what the different "chipping" companies reckon they can do with this engine in the Auris (either though a plug-in unit or remap). 205-210 BHP seem to be commonly quoted figures with 450 Nm of torque   s:shock: :shock: s:shock:  and that's without ANY other mods!
[size=85]Charlie
2001... with added
TTET. [/i]
My fuel consumption.[/size]
Quote from: "ChuckyBru"This is very interesting.  I'll be following your progress eagerly.
+1
Not something I'd do though. Keep us updated when you progress.  s8) 8) s8)
ChrisGB
With a remap that can be made to do a comfortable 330lb/ft and hold it out to around 3500rpm. Performance should be very strong indeed. Having owned a "performance diesel" with a remap, I can say that the driving style is a bit different. You tend to have to work the box more and you will need to adjust to shifting up at 4000rpm, but the performance potential is there.
I wonder how much potential it has for a bigger turbo and intercooler? Some of the Skoda Fabias are pushing up to 260bhp and 390lb/ft from a 1.9l engine.
Chris
MisterK
Having driven an Avensis T180 which I think has the same engine , I must admit that I was very impressed with the pulling power.  OK the power band isn't as broad as the petrol in the MR2, but I would think that putting one of these into the much lighter MR2 body would make it fly.  You might need to stir the gear lever a bit more to use the power but I bet the 0-60 would be impressive.  I hope to use Rogue to service my own MR2 once my Toyota service deal expires this year, so hopefully I can see developments in person, plus the racing roadster project in the MR2 challenge with 750 Motor Club.
Mark K
