Rear Diffuser
Started by uktotty, February 15, 2009, 15:59
Who makes this one then, is it MWR or is that toooo obvious?
Also fancy those exhausts!
StuM
That has to be the ugliest rear I've ever seen!   s:? :? s:?
There is a car in MR2 only this month with a home made diffuser that looks better than that one.  I know that they are functional items and that function over form is necessary.  Doubt that car would be legal over here though.
Is one of those tailpipes twice the size of the other?  Is there any logic behind that?
What that car needs more than anything is a couple more gauges...   s:lol: :lol: s:lol:
Stu M
LOL @ Stu
You are right though, they are differing sized pipes!
Mind you the uglieness maybe compensated by this
508 whp
10.85@130mph
one of the pipes is an exhaust the other is teh external wastegate pipe
StuM
Quote from: "markiii"one of the pipes is an exhaust the other is the external wastegate pipe
Ah.. I see!
Stu M
IIRC, MWR made that diffuser and it's just a one off for that car.
And the car was built for track, not for beauty contest.  s;) ;) s;)
 m http://store.monkeywrenchracing.com/ext ... 3965c21ev6 m
custardavenger
Quote from: "StuM"That has to be the ugliest rear I've ever seen!   s:? :? s:?
If you were ever behind it you wouldn't see it for long.
Diffusers can be functional but only when the vehicle has a flat floor and runs 20mm or less off the ground. the higher they get the less efficient they are.
I hadn't actualy seen that MWR had done that but am a bit dissapointed how similar to the one I'm doing it is. Mine will look better though  s:D :D s:D
Project Custard Clicky
DannyN
Biscuits tins for the 2 !!
You'll be giving markiii a run for his money then.......
[/size]
custardavenger
The reason I'm making one is cos his wouldn't fit without cutting them and there's no way I'm going to do that.
StuM
Quote from: "Tem"And the car was built for track, not for beauty contest.  s;) ;) s;)
Makes more sense seeing this:
Pic of MWR car with scantily clad young lady
ie. Without the bling wheels!
Quote from: "custardavenger"If you were ever behind it you wouldn't see it for long.
True enough.
Stu M
There was a CAR in that pic Stu?
Kool PT
wouldn't mind diffusing HER rear
wouldn't mind MY odd shaped pipe sticking into her internal waste gate
and so forth
