which OXY Sensor to buy?
Started by Anonymous, April 2, 2009, 13:52
After having an engine warning light come on it has been diagnosed by Toyota as a faulty oxygen sensor (OBDII Code:P0141)
The sensor that needs replacing is Bank 1 sensor 2 (Post CAT) after being quoted £235 by MrT to replace this I am looking to source my own and carry out the work myself.
I have found a cheap supplier in the US, but I am still a little uncertain it's the right Sensor I am buying here, can anyone please check the details below and advise if this is the right one, or point me to another supplier with the correct sensor?
 m http://www.rockauto.com m
2004 TOYOTA MR2 SPYDER 1.8L 1794cc L4 FI (R) [1ZZFE]
BECK/ARNLEY Part # 1564171
DIRECT FIT,Post Catalytic Converter  [/color]
Any help much appreciated...
THANK YOU!!
Chris
That's the right one.
And where i got mine from a couple of years back.
Be warned you will be hit by import duty and vat.
However worth it consideing what Toyota want to charge you - factor in a O2 Sensor socket / wrench too   s:wink: :wink: s:wink:
thanks, so there is no soldering involved as it's direct fit?
That's right, just plugs in and goes.
There are a couple of cable ties you need to cut though, but replacements come in the box with your new sensor
I just ordered one from  w www.onlineautomotive.com w  Also the cheapest price I could find for a CAT.
Quote from: "benji106"I just ordered one from  m http://www.onlineautomotive.com m  Also the cheapest price I could find for a CAT.
That's a search engine....which specific comapny was it?
gavw71
Bought an O2 sensor for my cat last year from Automedics, link below.
http://www.oxygensensors.com/
Got the one without a plug on because it was cheaper!  s:D :D s:D
Link to my original post below.
http://www.mr2roc.org/phpBB3/viewtopic.php?f=11&t=21552
17" Team Dynamics Pro-Race 1.2\'s, TTE lowering springs, front & rear strut top braces, Markiii inlet pipe, K&N panel filter, CHE header, Magnex dual exit exhaust, Dastek Unichip, re-map by Noble Motorsport.
