Stage 1, Stage 2, and stage 3
Started by VVT-i, April 16, 2009, 22:10
VVT-i
OK.. it's annoyed me long enough, I don't understand the "stages" of modifications which I guess only apply to turbo conversion (problably a wrong guess lol)
Anyone care to explain these stages and what the differences are?
2005 MR2 Roadster  (Black)
whatever the company offering it decides it is
VVT-i
I wasn't told what mine is.. so I've deceided it's stage 4   s:lol: :lol: s:lol:
Any examples of what would baisically be stage 1, stage 2, and stage 3... don't worry about stage 4, I've already got that  s;) ;) s;)
Ilogik
check out thor racing website, they go through what each of their stages gains.
But what mark said is spt on.
Ex: TRD stage 1 TTE Turbo
Yeah, what Mark said. Personally I've always tended to look at it like this:
Stage 1: Breathing mods only (intake + exhaust), possibly lowering springs as well.
Stage 2: Advanced N/A stuff (cams, pistons, more capacity etc) + single adjustment suspension. Aftermarket ECU as well.
Stage 3: Forced induction (either turbo or supercharger) and/or serious engine work, like race-spec engines or even complete engine swaps.
Some companies break it down further into 5-7 stages, but that's what I'd call them anyway. It's a bit like the whole bases thing when dating  s;) ;) s;)
Ilogik
for turbo you could do it at 200bhp, this would probably not need an ecu, and normal cooling, 2nd would be  more power, ecu needed, not sure what normal injectors are good for, then you got 3rd stage which would be 300 area, charge cooled, bigger injectors stand alone ecu, internals?
VVT-i
Quote from: "Dan M"It's a bit like the whole bases thing when dating  s;) ;) s;)
Can you elaborate a lot more on this... it's been a while lol.
My guesses would have been along these lines...
1, slip the mi....  s:oops: :oops: s:oops:   I mean...
1. Simple bolt on turbo (nothing else.)
2. Turbo, ECU cooling, clutch flywheel etc.
3. All the above and forged internals etc.
I honestly thought it would have been more defined than you say it is, it makes it hard to see how far someone has went when they say they have a stage # set up.
Anyway... back on topic... this dating lark and the stages lol.
Ilogik
Ilogik
Stage 1:
urbo installation, full stainless steel.
Supplied, Fitted and Mapped (NO Intercooling or Charge Cooling)
Parts List:
320BHP Garrett GT 25/28 Hybrid Turbo (including all oil and water pipes and fittings)
Stainless steel tubular manifold. (Equal length runners, designed and manufactured by THOR)
Mikalor Hose Clamps
Cone Air Filter
3" high flow Catalytic Converter (Or decat pipe if preferred)
3" Stainless Steel Exhaust pipe system
3" exhaust sports muffler
3" Chrome Exhaust Tip
GReddy Emanage (Installed and Mapped on the THOR Dyno for your car, not just a base map)
GReddy Emanage harnesses.
Set of four 420cc Bosch Injectors and injector clips.
Blow Off Valve, Toyota standard, HKS, Blitz, Turbo Smart etc. (price may vary dependant on choice)
2.5" stainless steel charge cooler pipework and THOR induction kit.
Stage 2:
Toyota MR-S Roaster Stage 2 turbo installation, full stainless steel.
Supplied, Fitted and Mapped with INTERCOOLER
EVERYTHING INCLUDED TO TURBO CHARGE YOUR MR-S Roadster.
Parts List:
Intercooler and fan
Mikalor Hose Clamps
Cone Air Filter
Stage 3:
Toyota MR-S Roaster Stage 3 turbo installation, full stainless steel.
Supplied, Fitted and Mapped with CHARGE COOLER.
Develops 240BHP at the wheels at JUST 9psi.
(That's about 280BHP Flywheel)
A 100% increase in power compared to non-turbo.
Barrell Charge Cooler (300BHP flow rate)
Charge cooler radiator and fan
High flow charge cooler water pump + control relay
Mikalor Hose Clamps
Cone Air Filter
That's just for a turbo installation though, and even more than that it's specifically for Thor's turbo kit.
Ilogik
looking at the above, the only thing i see different is the different cooling options, I would personally go for stage one, seems like a silly price increase considering everything looks to be part of the same kit.
Stage 3 tends to be the more extreme end of the scale.
VVT-i
Going by that I would more or less have stage 2, as I have an Intercooler as opposed to a charge cooler, I also have an uprated clutch and flywheel, although their estimated bhp figures for their particulr stage 3 arn't far off what I have (234bhp)
Thanks for the info guys... was one of those topics that was beginning to "dae ma heid in" lol
Anymore info on this dating thing yet though? lol
Star_69
Stage 1 is the first lot of mods, ie getting the turbo installed
Stage 2 always requires you to bolt things on you dont already have, regardless of the state of tune.
Any further ad hoc mods dont warrant being called Stage 3 unless it is implying to the other half that there is no stage 4, therefore no further money will be spent after this.
-Brad
Owner of an \'03 plate "Ship of Theseus" aka Trigger\'s Broom Roadster [strike]1zz-f[/strike]e, [strike]supercharged 2zz-ge,[/strike] 2GR-FE
Quote from: "Ilogik"for turbo you could do it at 200bhp, this would probably not need an ecu, and normal cooling, 2nd would be  more power, ecu needed, not sure what normal injectors are good for, then you got 3rd stage which would be 300 area, charge cooled, bigger injectors stand alone ecu, internals?
read the PE install manual without an ecu its a dangerous bodge
200bhp on stock ecu is not going to happen without a dead engine
Ilogik
Quote from: "markiii"
I didnt think the TTE had an ecu?
then read that manual too  :-) :-) :-)
it has a piggyback
I want to go the Spinal Tap route and go to 11 !  s:lol: :lol: s:lol:
Ilogik
Quote from: "markiii"read the PE install manual without an ecu its a dangerous bodge
it has a piggyback
Ay learn something new each day.
DannyN
Quote from: "markiii"then read that manual too  :-) :-) :-)
I have a problem with your answer Mark
Rightly or wrongly this club is predominantly Male orientated
And none of us read the manual !!!   s:lol: :lol: s:lol:    s:lol: :lol: s:lol:    s:lol: :lol: s:lol:
[/size]
Ilogik
Quote from: "DannyN"
its like flat pack furniture, untill the unit is upside down, and you lost half the screws do you let the girlfriend do it lol.
this would be a bad time to say I read them all cover to cover including the BGBs then  :-) :-) :-)
Ilogik
Quote from: "markiii"this would be a bad time to say I read them all cover to cover including the BGBs then  :-) :-) :-)
Do you listen to Elton Jon?
not regularly but I did once go to a concert does that count?
Star_69
Quote from: "Ilogik"Do you listen to Elton Jon?
Unfortunately listening to "Rocket Man" whilst installing a turbo DOES NOT make it go faster!
-Brad
DannyN
You'll do anything to get away from your better half
[/size]
