2nd gear....
Started by ex-member, April 18, 2009, 21:55
ex-member
No, not a cheap spinoff of the fifth gear tv show...!
Recently....my 2 has been reluctant to go into 2nd gear....it doesnt crunch etc so im hesitant to say it's the syncros, but just occassionally, it doesn't fancy shifting into 2nd as smoothly as the other gears (ie, it take a bit of a pull to move it).
I've yet to check gear oil and the likes, but any other ideas folks?
kentsmudger
Have a look at the clutch pedal adjustment How-To on Spyderchat, sounds like similar symptoms.
ex-member
Interesting! and not something I'd have considered!
Cheers for the link mate  s:) :) s:)
woth checking teh clutch fluid level on that basis
also check for any gear oil leakage, I made sure it was filled and tight before you collected but just in case
if neither work I;d remove teh centre console and grease teh shifter ball
darkday
ex-member
Cheers guys!  s:D :D s:D
Mark, do I recall reading the car had a rebuild of the gearbox, or some gearbox issues prior to me taking ownership?
it had a replacement 2nd hand gearbox after my original grenaded yes
ex-member
Cool cool! Any idea how many miles it had done/ has done now?
afraid I have no idea
