Camber Bolts questions
Started by Rowland, June 23, 2009, 07:45
Rowland
Hi all,
I've got a few camber bolt related questions if I may.
1. I believe there are OEM Camber Bolts available from Mr T to give a small degree of adjustment.
Are these available for both front and rear axle on the Roadster?
2. Is it one bolt per corner or two?
3. Does anyone have part number information they could post up please?
As this is for my race car I'd like to fit these Camber bolts and then spend some time and money on an optimal wheel alignment before the next race.
Any help much appriecated from the ROC guru's.
Rowland
  s:D :D s:D
you can fit as many as you like in either top or bottom to get eh desired camber however they aren;t cammed bolts so they will move under enough stress
possibley more of an issue when racing or maybe less so if your checking them after each race
custardavenger
If they are for the race car I would use proper top plates and adjustable bottom links if you can. Camber bolts are not something I would ever fit.
Project Custard Clicky
Rowland
Quote from: "markiii"you can fit as many as you like in either top or bottom to get eh desired camber however they aren;t cammed bolts so they will move under enough stress
Thanks Mark.
  s:) :) s:)
no probs part numbers below
Camber adjust bolt number 1   90105-14146
Camber adjust bolt number 2   90105-14147
