2ZZ swap ECU question
Started by Anonymous, August 5, 2009, 20:24
Hi all,
I'm planning to do a 2ZZ swap into my 2001 MK3 shortly.  The donor car is a 2003 Celica.  I've bought (but not yet collected) the engine, ecu and 6 speed box.  My question is - presumably the 2ZZ ECU is immobilised?  What is involved in getting it re-coded for my existing key - does it need a visit to a Toyota garage?
Thanks,
Mark
if you can;t get the keys
speak to Chris at Cheap toyota parts he should be able to assist
Thanks for the reply.
If I get the original key , whats the score then with getting the Celica ECU to work with my existing MR2 key?
swap the insides of teh celica keys into your roadster key
Ah - simple...! Thanks Mark.
Does anyone know if there is a pinout diagram for the 2003 Celica ECU floating around - the one I have is for a non-immobilised ECU (at least, I assume it is as there are no immobiliser pins shown)...
