Pre-cat removed - now Malfunction warning lamp on!
Started by CeeJay72, March 13, 2010, 12:35
CeeJay72
#75
Quote from: "CeeJay72"
Quote from: "life of bryan"Yes but how much would it have cost you if you hadnt come here?
I hate to think what my local toyota dealership would have charged me!
  s:D :D s:D
To all that helped - many many thanks!  I owe u all a beer!
Now - lets just hope the warning lamp stays off!
C
That fault light is like my ex-girlfriend.  Just went you think she's finally taken the hint and decided to leave you alone she's back - just when you didn't expect it...
Yes you guessed it.  The lights back on - after 3 days I thought it was behind me - obviously it has other ideas.
OK I'm off to torch the f**king thing...
  s:evil: :evil: s:evil:
C.
muffdan
#76
ok, pull the code and lets see what we're dealing with.
CeeJay72
#77
Quote from: "muffdan"ok, pull the code and lets see what we're dealing with.
Hi Dan
Its codes 171 and 174 again!
Regards
C.
muffdan
#78
Probably an air leak if both banks are reading lean. That or the fuel pressure is too low. Have you checked all pipes are properly connected and secured between the MAF and the inlet manifold?
CeeJay72
#79
Quote from: "muffdan"Probably an air leak if both banks are reading lean. That or the fuel pressure is too low. Have you checked all pipes are properly connected and secured between the MAF and the inlet manifold?
I have done - but I'm going to check each pipe now.
Perhaps one of the pipes has a cut or tear - hopefully its something simple!
C.
CeeJay72
#80
C.
No loose hoses or rears/rips etc evident...
Hmmmm....
C.
muffdan
#81
That sucks dude.   s:( :( s:(
CeeJay72
#82
Quote from: "muffdan"That sucks dude.   s:( :( s:(
Having looked around on the net, I think the next thinks to look at are the fuel pump and the injectors.
I think it might be best thou if I find a good garage and get them to have a look rather than me just replacing everything!
C.
muffdan
#83
I'm not sold on the injectors, there would have to be two that are faulty to cause both codes to trigger. Does the car feel ok when you're driving?
CeeJay72
#84
Quote from: "muffdan"I'm not sold on the injectors, there would have to be two that are faulty to cause both codes to trigger. Does the car feel ok when you're driving?
Yes it feels brilliant - its fast, smooth and very responsive - I don't feel that this is a mechanical problem as the car just drives far to well for there to be an engine issue.
C.
muffdan
#85
then I think we're back to an air leak.
I think you're right and you're at the stage where this is going to have to be taken to a garage.
CeeJay72
#86
Quote from: "muffdan"then I think we're back to an air leak.
UPDATE:  I dropped my roadster off at Toyota in Edinburgh and they've found that its the NEW  MAF Sensor thats at fault.  They swapped it for an old one they had on another roadster they had in stock and bingo - fault gone.  So I'll be calling CamSkill first thing tomorrow to arrange an exchange.
I cant tell you how much worry this caused me - I was beginning to think I had major engine problems, so its a relief to know that its just a simple sensor thats to blame...
I need a beer.  And a whiskey.  And another beer - and perhaps another whiskey...
Regards
C.
nathanMR2
#87
Good news. Just hope that sorts it mate
CeeJay72
#88
Quote from: "nathanMR2"Good news. Just hope that sorts it mate
So so I!
Wow how unlucky,glad it seems to be sorted and it hasnt made liars out us all!  s:lol: :lol: s:lol:
CeeJay72
#90
Quote from: "life of bryan"Wow how unlucky,glad it seems to be sorted and it hasnt made liars out us all!  s:lol: :lol: s:lol:
I just hope Toyota are right and its the MAF sensor, as the supplier is skeptical.
They had no problem suppling me with a new one (as the parts guaranteed), but they've never had one returned before, so they feel that its more likely that the MAF is getting fried by an electrical pulse...
I suppose only time will tell!   s:| :| s:|
Regards
C.
CeeJay72
#91
Regards
C.
Update:  There have been no error codes for almost 5 weeks now, so with fingers crossed I say 'I think its fixed'...
Looks like I had a 'bad' new maf sensor.
All the best!
Craig.
muffdan
#92
WooHoo!   s:bounce: :bounce: s:bounce:
Good news  s:) :) s:)
CeeJay72
#93
Quote from: "muffdan"WooHoo!   s:bounce: :bounce: s:bounce:
Lol - it certainly is!  Although I must admit I'm still worried that the gremlins while come back!
Again thanks to all that helped me with my queries.
C.
