where is the thermostat housing?
Started by marco2412, March 13, 2010, 18:19
marco2412
hi there i think my thermostat is stuck open can anyone tell me where abouts it is in the engine? thanks pic would if uyou can!  s:D :D s:D
It's on the intake side of the engine, between the alternator and intake manifold.
You can change the thermostat from above, no need to remove much of anything. Just feel your way around...
(it's where the rubber coolant hose goes to)
I'll see if I find a pic...
Quote from: "Tem"I'll see if I find a pic...
Not the best pic, but you can just see it between the alternator and intake manifold.
(ignore the manifold, yours will be black and plastic, but the housing is there anyway)
 m http://www.aijaa.com/v.php?i=5899869.jpg m
marco2412
Quote from: "Tem"
ok thanks but how do i get down there as it is very tight when its in the car,  s:D :D s:D   plus thats the rear of the engine isnt it? thanks
its on the firewall side of the engine
looks easier to do from below to me
SteveJ
Quote from: "markiii"its on the firewall side of the engine
Not if you've got aircon it aint   s:wink: :wink: s:wink:
Drop the alternator off it's mounts and it's not that difficult to get at.
IIRC, I couldn't get to the nuts from below, but they were no problem from above. Or maybe I was just too lazy to lift the car, can't really remember, it was last summer when I changed the thermostat. I just remember it ended up being a lot easier than I thought.
I didn't touch the alternator, nor anything else. The engine plastics are off on my car, can't remember if it would get in the way or not though. Just undo the two nuts and it moves enough to get the thermostat out and back in. No need to undo the hose or anything else.
