Where is the steering fluid located?
Started by Anonymous, May 22, 2010, 19:46
As mentioned....because im baffled! lol
ChrisGB
Quote from: "speed_queen86"As mentioned....because Im baffled! lol
Under the front plastics.
Chris
under the bonnet at front?
Here you go.
ChrisGB
Specifically, you open the bonnet, then remove all the plastic poppers that secure the plastic trim that surrounds the spare wheel well, remove the trim et viola!
EDIT: The poppers are removed by pushing down the middle sections with a small screwdriver, then you can easily lift them out.
Chris
Wow FAB thank you very much!!  :-) :-) :-)
this and other useful info should be in your owners handbook
