Air intake idea
Started by ad_car_08, August 10, 2010, 16:24
ad_car_08
Hi,
It's been fairly quiet at work, so I've had plenty of time to daydream and think over a few ideas for my car   s:lol: :lol: s:lol:
At this stage I'm only "spit balling" (as those americans say!) and I accept I might be missing something glaringly obvious. Anyway, my idea...
The standard location for the air intake, seems to be fairly efficient in the way of pulling cool air, rather than relocating it which can sometimes mean the intake pulls in warmer/hotter air than it used to. What the standard location does lack, is a forced induction type feed of air..
I wondered.. if I could find a really free spinning fan in a frame, like a computer fan take my markiii air pipe, grab a dremel and cut a slot out of it, big enough to slot the fan into it... Now, my thought was that when the engine sucks air, it will pass over the blades of the fan causing it to spin, pulling more air, making the fan spin faster, which pulls even more air and providing an increased amount of air to the engine, sort of emulating forced induction?
Possible flaws could include;
- stiff fan restricting airflow more than aiding it
- careful choice of fan to make sure the angle of the blades don't restrict airflow & create the best effect of pushing the air towards the airbox
- obviously the slot that was cut to slot the fan into the pipe will need to be sealed so air doesn't escape.
Advice and opinions are most welcome. I'm curious as to whether this would work, theoretically?
[/size]
assuming it did evetually either teh fan would explode or the engine would.
in reality unless your going to produce more than 1 bar your not going to fill teh cylinders with any more air than gravity already manages
and that fan isn;t going to produce more than 1 bar.
and in reality it won't work anyway as there is no such thing as free energy
Not wishing to upset you here so bear with me.
What you are suggesting is perpetual motion  m http://en.wikipedia.org/wiki/Perpetual_motion m
You can't generate more air pressure from a fan by sucking through it ... unfortunately.
The only fans that can achieve this are jet engine turbines and the reason why they achive this is because they have a load of fuel duped into them and ignited, thus driving the fan blades.
Good try though, I've always wondered about model aeroplane ducted fans with brushless motors in them, but the energy you need to drive would probably overtake the benefites.
ad_car_08
No no, it's fine!
I knew there must've been a reason why it's not already been done!
Thanks for your replies   s:D :D s:D
[/size]
ad_car_08
I wonder what, in an ideal world, it would take to increase airflow?
Increased pipe diameter with fan? actually powering some form of air propulsion whether it be a fan, or more like this kind of arrangement??
You see these things spinning quite fast!
[/size]
Not going to look too good though, stuck on your car.  s:lol: :lol: s:lol:
ad_car_08
 s:lol: :lol: s:lol:   too true!
I know it's probably not financially efficient/realistic to replicate...I just get intrigued by these things   s:oops: :oops: s:oops:
[/size]
Mad Matt
Well, if the fan isn't powered it will restrict air flow, compared to not having it. If it is powered, it will just take power off the engine, unless you can get the pressure above one bar (as said above). I believe a possible solution would be some kind of turbine driven off the exhaust...... hmmm.
I was also told by a mate that from an aero point of view, even an air scoop (or ram air) isn't going to get you much until you reach about 80mph and even then......
Save the time and get yourself a "Turbonator".  s:lol: :lol: s:lol:    m http://cgi.ebay.com/ebaymotors/DUAL-TUR ... ccessories m
Gif
Tried adding snake oil to my petrol but even that only yielded a couple of BHP   s:lol: :lol: s:lol:
Audi TT 200 Tfsi Roadster, Ibis White, Steptronic, Bose, Nav, Climate, Telcon, Nappa Leather
Ex BMW Z4 sDrive30i Auto, Titan Silver
Ex MR2 Roadster, Sahara Sun, Black Leather, Air Con, TTE exhaust
nathanMR2
or even  m http://cgi.ebay.com/ebaymotors/Toyota-E ... ccessories m    s:roll: :roll: s:roll:
