Manifold Studs?
Started by weddallenko, September 29, 2010, 22:09
weddallenko
Hi Guys,
I am new to the forum and am after a bit of advice, I am looking to replace the exhaust manifold on my 1ZZ.
Purely a preventative measure so my pre-cats don't cause any aggro in the future...
Now the studs that screw into the engine look in pretty bad shape, corroded, so before I embark on any removal I'd like to get new ones ready (just in case I have trouble)
Does anyone know what size thread / length these studs are?
Or has anyone had similar troubles with this type of maintenance?
Many thanks in advance.
N
"One Lady Owner" - So the Clutch is f*cked then...
there are 5 and they are available from Toyota
Make sure you get the gaskets too
weddallenko
Cheers uktotty,
I have got the gaskets already but need to get the studs soon.
I have checked out ebay, seems to be loads to choose from - so really need the thread size and stud length.
Does anyone know what size they are?
A search brings up the answer on the first page, and that answer is just to get the proper Toyota ones as they have the shoulders in the right place.  s;) ;) s;)
SimonC_Here
search terms:
manifold stud size
Quote from: "weddallenko"Cheers uktotty,
Dont check out eBay check out Toyota, your local dealer.
Or Cheap Toyota Parts
They are only a couple of quid each - not worth the risk.
OldMan
Part number (at least in the USA) is 90126-08037 "Stud Hex Lobular".
weddallenko
Thanks for all the advice guys!
