oil light
Started by Anonymous, November 3, 2010, 13:54
once on the ignition position, which light shold stay on? i'm getting the oil light on ignition position which never happened before, and when i start the engine it goes out!
what should i look at? i've checked the oil level and it seems to be fine. well although the oil stick show something and not in the minium
Quote from: "blackskylinegtr"i'm getting the oil light on ignition position ..... and when i start the engine it goes out!
Thats the way it should be.
E
Quote from: "spit"
+1  The light comes on with ignition key for a bulb check and should stay on as there is no oil pressure until you start the engine then the oil getting up to pressure turns it off.
In fact that happens to all the lights.
Worth checking them all, because fraudulent sellers have been known to disconnect the CEL to ensure an engine problem is not highlighted to a potential buyer.
