sports cat
Started by rosco1209, November 13, 2010, 11:08
rosco1209
will this be okay and run fine in replacment of the standered cat    m http://cgi.ebay.co.uk/High-Flow-Sports- ... 84ff08e86f m
many thanks
Would be fine-ish but you will need to have the pipework fabricated to connect it in obviously.
What you have to remember about sports cats is that they are not as efficient as a normal catalyst at being a catalyst and you would encounter engine lights without other modifications like PeteT has just had to do. You will get through an mot though as long as it's been warmed up properly. Possible cheapest option is to get a de-cat pipe and cut and shunt one of these in, but they are usually 2.25", not as straight-forward as just replacing the standard cat   s:wink: :wink: s:wink:
PeteT
Thanks Nic, Here is the thread here
Since the mod, i have had no CEL's  s:bounce: :bounce: s:bounce:
Pete
