Plug and Play injector 'clips' / connectors
Started by PaullyP2010, November 29, 2010, 19:52
PaullyP2010
Hi All,
Apart from MWR, is there anywhere else to get these adapters from, I am currently getting Nicks old Hass kit fitted   s:bounce: :bounce: s:bounce:  , and would like to use these instead of getting the wires cut / soldered if possible.
Grateful of any info, or does anyone have some they aren't using that I could buy?
Cheers,
Paul
2003 Sable Grey
Built 2ZZ Turbo with lots of other goodies.........
Hi paul.
MWR is the only place I've seen these available. What size are the injectors you're switching to?
PaullyP2010
Quote from: "spit"Hi paul.
Thanks Ste,
I thought that might be the case, never mind! Unsure on the injector sizing - I assume whatever the Hass kit came with as standard - 440cc?
Dont have the kit here now, as car is away getting fitted   s:D :D s:D
Cheers,
Paul
2003 Sable Grey
