4 x 100 & 4 x 108 fitment
Started by uktotty, January 31, 2011, 13:59
So will these fit my car??
Ilogik
Quote from: "uktotty"So will these fit my car??
Pretty sure my old wheels were 4x108 on the rear.
Ex: TRD stage 1 TTE Turbo
think about what pcd means
you'd probably get away with it
not sure I would though
VVT-i
PDC on the roadster is 4x100, so in that respect they will fit, but you need to check the offset, should be between et35 and et45.., the right offset for the wheels depends on the J size, ie how wide the wheels are.. 6.5J, 7J or 7.5J etc.
The fact these wheels are 4x100 and 4x108 just means they are multi-fit for various different cars, some with 4x100 other with 4x108.. there are 8 holes for wheel nuts/studs instead of just the 4.
2005 MR2 Roadster  (Black)
not sure if russ was saying they supported both so much as saying that would x 108 fit  x100?
Yes the wheels I am looking at have both fitments. Kei RSS
ok in whihc case its a really simple yes
Yes Russ, it's just they have 8 holes.
4 of them are 4x100
4 of them are 4x108
Therefore just pick the hols all the studs match.
VVT-i
Going for the Innox lip?  I had them on my Yaris, sweet looking wheel but damage the innox lip and you will find it hard to repair and most likely cheaper(ish) just to buy a new wheel. I know because I had to buy a new wheel (kie kruze.. innox lip) for my roadster after kerbing it.
brad82
Quote from: "uktotty"Yes the wheels I am looking at have both fitments. Kei RSS
i have them on my car russ they fit fine   s:D :D s:D
EX SP240 gone, BMW Z4M gone, Audi s3 + something else arriving soon
I thought you did and I love em! How did you do the stagger brad ?
brad82
I have got 195/40 17 on the front and 215/40 17 on the back, they are toyo proxys px 4 theres not much choice in that size really could go to 225/45 on the rear with 205/40 front but this put the rolling radius out a bit more...
