1500 rpm idle speed
Started by Anonymous, May 25, 2011, 16:22
Hi,
My 2003 MR2 has a high idle speed of 1500 rpm.
This is typically associated with crud on the idle control valve on Fords etc - it is the same on our roadsters ?
mr-ed_smt
clean your MAF first of all. and reset ECU
Thanks, I searched the forum (and others) and found that thread and others that conflicted and mentioned a 750rpm idle speed.
Confused !
Yes starts off high and drops to around 750rpm when engine is warm.
Agree with LOB. If its only that high when its cold and the "choke" is out, but drops back to around 750/500 when warm, don't worry, its normal.
Just to add to this. If your revs aren't dropping noticeably after a warm-up period then it is as you hint likely to be a stuck idle air control valve. These are crazily over-engineered on the Roadster and can get gummed up.
If this is the case, let us know and we'll point you to it.
russw69
my idle speed does not drop even when the car is warmed up, even when the rad fans com in it still idles at about 1500 to 1600 rpm, any help or advise please?
Quote from: "russw69"my idle speed does not drop even when the car is warmed up, even when the rad fans com in it still idles at about 1500 to 1600 rpm, any help or advise please?
All the clues to fix this are in this thread.
russw69
Air idle control vavle removed stripped, cleaned and oiled runs like a dream now.   s:D :D s:D
JudoKilli
Just to continue this thread a little bit, mine seems to be hitting on the normal speeds, but when at 600_750 it sometimes feels as though the engine might drop out, as if its about to stall, judders a little, then recovers.
