Passenger Window Jammed
Started by Anonymous, July 14, 2011, 09:22
Hi Guys,
My passenger window stopped working, it would go down but not back up - very annoying when this happens at midnight! After doing a quick search when it happened the only replies I could find were advising to check the passenger window safety switch. (If you are experiencing a problem with the passenger window this should be the first thing to check!!). Secondly, I swapped the fuse from the drivers window which was working, and still no luck it wasn't moving.
In the end, I shook the window whilst getting whilst someone to press the switch - Luckily after a couple of goes the window started to operate. So before you start to panic, try to wiggle the window and it can simply just be jammed.
Hope this helps someone in the future!
WS
