1ZZ UK and Import
Started by ginger1, October 11, 2011, 13:28
ginger1
Are there any differences between the UK and Import 1ZZ engines?
Looking at replacing my 2002 UK 1ZZ, and had a quote on a 2005 Import 1ZZ 38k km and 2004 UK 1ZZ Rebuilt, £150 difference.
Curious if it's worth it.
Broken \":-(\"
The import engine lacks the oil cooler/warmer water fittings, so you have to do a little re-plumbing and lose the sandwich plate on the filter housing.. IIRC that's the only difference.
ginger1
So I may as well go £150 cheaper and have the Rebuilt 2004.. then no plumbing.
Just wondered if there was any more hidden power in it =]
("All our reconditioned engines have cylinder heads tested & skimmed, new stem & crankshaft seals fitted, new piston rings, new main & big end bearings, crankshafts either reground or polished, and are supplied with a new gasket kit.")
Broken \":-(\"
