Engine light but strange codes
Started by zen200, October 11, 2011, 13:38
dcod
Go to ebay and search for 'OBD2'. There are lots of them. Take your pick.
  s:D :D s:D
Late Corsa C are CANBUS, early Corsa C are not (though if it's like the Omega B, ELM323 based readers won't work as they don't support the required OBD-II protocol).
dcod
Quote from: "zen200"Or is this yet another obd2 ?
Sorry, misread this quote, thought it said "Or is there yet another obd2". My bad. Damn my disluxia.
zen200
Hi all,
Quick update.
1) Garage said that my gearbox reverse crunch is a common thing and that many cars including new ones crunch into reverse gear as there is no synro on reverse. I can say that I use a brand new vauxhall astra and that also crunches into reverse gear also. So nothing is gonna be done about it. Solution is to either press clutch and wait for several seconds for flywheel to slow then put into reverse or put into 1st gear before you then put into reverse which solves it nicely.
2) I tried to use my VAG COM USB DIAGNOSTIC CABLE 409.1 OBD2 II KKL with free software that I found, but I didnt ever get it to pick up anything. So im only guessing that the cable is specific to VAG COMPLIENT and cant be used with non VAG  software.
If anyone has an other software that they know works with  OBD2 VAG usb cable then please let me know.
3) Have bald inside edge of front tyres. This is again a common thing with the standard MR2 Camber Setup.
dcod
2.  m http://www.talktomycar.co.uk/products/i ... /mj020.htm m
You'll notice as you scroll down that you may need the USB driver as well. That may be the problem with your current software.
zen200
OK I will try that when I get home later on.
Thanks.
Unfortunate the usb dongle isn't working ... but there must be some software out there does work!
You must be a bit over-keen getting into revers   s:wink: :wink: s:wink:    s:lol: :lol: s:lol:  , don't worry take your time and be patient.
as for;
Rubbish!
On some lowered cars without adjustable topmounts this can happen - but it's rare, but I've never seen it on a standard setup.
dcod
Quote from: "Wabbitkilla"Rubbish!
+1
I've never experienced it.
chopper
It sounds to me that you have a jap import version and the obd2 readers wont work on them you need a JOBD reader wich is very hard to find its more a software issue as the hard ware (the usb cabile) is more or less the same but there may be difrances between them
the paper clip trick works or on jap versions but not on eu versions as far as know
zen200
My car is defo uk car with one previous lady owner.
I have read other threads and dont wanna make a new one, but if what is being mentioned on this thread about the tyre wear not being a typical issue with the MR2 Roadster then I need to try and find the reason of this.
To give a bit of background.
I have had the car since March and it has nearly always made a skipping noise when being put onto full lock and reversing. Car feels like it is on a big stone and skipping. this I have read can be due to warn tyres and worse when cold. I am therefore replacing the tyres with toyo proxes in the next few weeks and will report back if it changes things.
However, I dont wanna wear through another set of new front tyres so is there a way to check shocks/top mounts/ steering etc. I would do this before I fit new tyres and see if there is something else thats the issue.
Thanks for your thoughts.
dcod
1) Make sure you put on the correct size tyres with the correct stagger.
2) Make sure you get your wheel alignment done. (This could be your problem).
I have Toyo Proxy T1Rs and all is peachy.
Post your current tyre sizes and someone should be able to tell you if they are correct.
zen200
#36
My Tyre sizes are
Front
185 / 55 / R15  81V  Yokohama
Rear
215 / 45 / R16 86W Yokohama
I had the tracking checked and its spot on, but both front tyres have warn the inside 1/4 edge of both fronts (the rest of the tire has loads of tread left)
1. Could this have something to do with my clunking noise on full lock.
2. Could this be suspensions issues if so what should I check for ?
3. What type and size of tyres would you recommend I get if I am only changing the fronts as the rears are in very good conditions still ?
1. No
2. Possibly, but first;
Did you have your camber checked or just toe?
QuoteDamn my disluxia.
Bit off topic, but years ago I saw a sign in the gents which read Lexidysia Lures, KO!
Took me about 10 years to work it out.  s:oops: :oops: s:oops:
zen200
Quote from: "aaronjb"1. No
I had the toe I think.... Is the camber adjustable then ?
zen200
#40
I have read threads on the net and im sure on here that people said that old warn tyres make the car skip, clunk on full lock in reverse. They said that its due to the tyres. Then when they put new tyres on it stop the issue ?
