ebay Turbo kit for £30 !!!!
Started by Anonymous, April 22, 2004, 10:18
Just saw this and it cracked me up !! Surely this is the new must have accessory  :-) :-) :-)
 m http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 7900637459 m
TOYOTA MR2&CELICA TURBO&SUPERCHARGE SIMULATOR
YOU SIMPLY INSTALL THE DEVICE INTO YOUR EXHAUST PIPE, ADJUST TWO SCREWS AND WHAM!!
PEOPLE DRIVING NEXT TO YOU WILL BE WONDERING IF YOUR CAR IS SOME TYPE OF PROTOTYE!!!--IN MOST CASES IT ACTUALLY SOUNDED BETTER THAN AN AFTERMARKET TURBO !!
--THE SOUND BEING EMITTED IS SO PRECISE, IT PLAYS A TYPE OF "TRICK" ON THE EAR!!!...
WHEN YOU HIT THE GAS, AIR IS BLOWN OUT OF YOUR EXAHUST AT HIGH PRESSURES. WHEN YOUR EXHAUST AIR HITS THE SOUND DEVICE, IT WILL PRODUCE A HIGH PITCH, OR LOW PITCH(DEPENDING ON HOW YOU ADJUST IT) "SPOOLING" SOUND...
ONCE YOU GET USED TO DRIVING WITH THE DEVICE ON YOUR CAR, YOU WILL REALIZE THAT YOU CAN CONTROL THE WAY IT SOUNDS DEPENDING ON HOW YOU DRIVE..... NORMAL DRIVING, FOR THAT HIGH-TECH PERFORMANCE SOUND , OR FAST ACCELERATION  FOR INTENSE, LOUD, INTIMIDATING  SOUND.....
**JUST LIKE A REAL TURBO SYSTYEM!!!**
[ Well not quite like a real turbo ]
ADMIN*** thread locked due to duplication ***ADMIN
