Bereft this weekend!!
Started by 2 of the left, February 17, 2012, 20:36
2 of the left
The 2 had to go into intensive care this forenoon.I've been nursing it for a few weeks now - Adding coolant daily, knowing there was a leak in the system - just could not determine exactly where - Well the 2 gave up her secret yesterday - Nearside bottom of Radiator (obvious road damage to corner)Luckily because of cold weather no overheating has occurred!! - Now - what shall I do this weekend - Origami, Flower arranging or sit by the phone waiting for updates on replacement?  s:cry: :cry: s:cry:
SI VIS PACEM PARA BELLUM!!
redarrow
Why didn't you just replace the radiator your self?
I was told it a easy job, maybe it a lie.
what the total in cost ?
member uktotty mastered it.
http://www.mr2roc.org/phpBB3/viewtopic.php?f=11&p=341812
Take the front plastics out, take the alarm with it just unplug.
Remove the 2 brackets under that which hold the bins and the rad in place.
Break off the 2 rusty bolts in the process or use lots of plusgas.
Remove the hoses (bit of a bugger) take out the rad to see all the holes in it.
reverse the process.
Here's a howto for coolant bleeding:
http://www.spydermagazine.com/2002/Nov/coolant/coolant.htm
oh yeah Coolant is a good idea, it takes about 6.5 litres IIRC
proper full guide with pictures.
http://www.mr2oc.co.uk/know-your-2-knowledge-base.html?kbartid=161
regards redarrow.
[size=85]These are the dreaded code your get with cheap 02 sensors.
P0135 drivers side position. (o2 sensor heater malfunction (bank 1 sensor 1)
P0155 passengers side position. (o2 sensor heater malfunction (bank 2 sensor 1)
P0141 passengers side down below exhaust position. (o2 sensor heater malfunction (bank 1 sensor 2[/size]
2 of the left
No tools - uneven ground in driveway (Gravelled)
kentsmudger
Quote from: "redarrow"proper full guide with pictures.
regards redarrow.
That won't get you very far on a Roadster!
2 of the left
Don't I know it!!!
Even if posted in English, it won't help if you have no tools. I wonder if the end cap seal have given up on the rad? Had one of those blow myself a while back.
2 of the left
Had full inspection by self - definitely struck by something that has clipped the corner  s:twisted: :twisted: s:twisted:  New Rad needed
2 of the left
Have been quoted £240 for change of Rad (my 2 apparently a "Grey Import") + MOT - plus removal of Precats should they be found in motor - Opinions please  s:?: :?: s:?:
£70 for a rad
3 hours labour £90
Gasket £10
Coolant £18
2 of the left
Quote from: "uktotty"£70 for a rad
3 hours labour £90
Gasket £10
Coolant £18
That sounds about right then considering the 2 hour knockout of Precats - If they are there!!!
Sounds good value at £240. Id be interested to know what the actual bill is.
2 of the left
Actual bill came to £290 and no precats onboard - Walking on air when informed - I paid up without quibbling  s:bounce: :bounce: s:bounce:  And the 2 sailed through the MOT!!
Sounds fair.
2 of the left
Got an advisory on the MOT though - front tyres showing deterioration on outside edges even if the treads are well within limits- So I reckon I'll bide my time.Both are Toyos and as far as I can tell they are still available but not so common as they used to be.Am I right?
G20
Quote from: "2 of the left"Got an advisory on the MOT though - front tyres showing deterioration on outside edges even if the treads are well within limits- So I reckon I'll bide my time.Both are Toyos and as far as I can tell they are still available but not so common as they used to be.Am I right?
I got Toyos from camskill last week, good price too.
2 of the left
How much for fronts 15" ?
2 of the left
Quote from: "dick2ski"http://www.camskill.co.uk/m53b103s0p0/Car_Tyres_-_MPV_Tyres_-_People_Carrier_Tyres_-_15%5C_inch_TOYO_TYRES_CAR_TOYO_T1R_PROXES_TOYO_T1_R_-_
Cheers for that - I now have starting point to work from and it looks like they are still available.(from Camskill anyway)
Steve Green
Quote from: "redarrow"Why didn't you just replace the radiator your self?
regards redarrow.
So much better to hear from someone, in their own words, who has done the job themselves.
A series of links, sometimes from different cars only leads to confusion.
I've never done the job myself but advice from the likes of Mkiii or D!ck2ski and many others who see a Mk3 regularly, carry much more gravitas.
2003 Facelift SMT
Did my old avatar offend you?
G20
Quote from: "2 of the left"How much for fronts 15" ?
I put 195/50/15 on the front at £34 each, and 225/40/16 on the back at £63 each.
£10 a corner to get them fitted from a local garage.
2 of the left
Quote from: "G20"
Looks like overtime is in the offing then  s:wink: :wink: s:wink:
