Weight difference standard v decat manifold?
Started by Zonda_, February 20, 2012, 13:43
Zonda_
Does anyone know the weight difference between the two? The place that fitted my decat manifold gave me to original one back, dunno why, but I was amazed how heavy it was.
2001 Roadster, che manifold, 40mm lowering springs, BMC Carbon intake mounted behind battery.
Who cares ... go weigh in the catalyst material   s:wink: :wink: s:wink:
stargazer30
Well cast iron vs stainless steel so yup you'll save a bit.  You want to feel the weight of the stock silencer can, thats bloody heavy too vs an aftermarket SS cat back.  If you want to do a weight reduction replace both, loose the spare wheel but relocate the battery to the front to keep the weight on the front wheels.  I recon that would save you a good amount of kg and make the car quicker.
Zonda_
How would you go about relocating the battery?
mrzwei
Quote from: "Zonda_"Does anyone know the weight difference between the two? The place that fitted my decat manifold gave me to original one back, dunno why, but I was amazed how heavy it was.
Sad I know but I weighed mine when I did the swap some years ago.
Stock manifold with intact precats - 4625g
Che manifold - 3500g
Top heatshield (left off) - 1250g
Total saving - 2375g
Ex.MR2 SMT sadly missed.
Zonda_
Thanks for that, now to weigh the spare wheel...
manchestermatt1986
I have removed my spare wheel, and yes it saves weight but i worry that Toyota obviously calculated the car with the spare wheel being there. Now i know we all add aftermarket parts and do this and that to the cars. But i would of thought that the front being so light already if you were to take out the front wheel it is quiet a big disturbance to the balance of the car. They don't spend millions designing the cars for nothing. As i say, i have taken it out so i sound like I'm contradicting myself   s:? :? s:?
Toyota/TRD Stage 2 Kit - C-one Wing - Hardtop - Injen Induction - Inner Vent LED\'s - Double Din JVC - Armrest - Painted Calipers - Custom Heatshileld - Two Active Subs In Bins - Blitz Nur Spec-S - Team Dynamic 16" - Twin Vocal Speakers On Bin Lids - JSpec Gear Knob - Che Manifold - Angel Eye Fogs -
Zonda_
Then you're in the perfect position to comment, did it make a difference to the handling? I can't see that it would.
ChrisGB
I replaced the stock manifold and cat with a PPE setup. I could feel that the rear end was a little lighter and settled a fraction easier, but the biggest difference came from replacing the exhaust with something really light. Noticeable when making multiple quick direction changes, not a huge difference, but all good. The exhaust is heavy and sits high up and well rearward, so reducing the weight of this makes sense,
Chris
