swapping back lights pre with current.(SOLVED)
Started by redarrow, March 14, 2012, 18:37
redarrow
Hi there all.
 I want to get the new looking back lights and add to a 2001 mr2, I want to no if it a easy job, or any medication to do cheers.
regards redarrow.
[size=85]These are the dreaded code your get with cheap 02 sensors.
P0135 drivers side position. (o2 sensor heater malfunction (bank 1 sensor 1)
P0155 passengers side position. (o2 sensor heater malfunction (bank 2 sensor 1)
P0141 passengers side down below exhaust position. (o2 sensor heater malfunction (bank 1 sensor 2[/size]
Chris H
When you buy the face-lift lights,try and get them with the wiring harnesses and
its a simple plug and play..  s:) :) s:)  ..if you dont get the harnesses,you can use your current
one's,but would need to trim the indicator part to allow for the old indicator bulb
to fit.......better if you get the lights with the harnesses.....hope this helps...  s:roll: :roll: s:roll:
redarrow
ty.
SOLVED
