Clonking After Rear Disc Change
Started by alfajerry, March 27, 2012, 16:44
alfajerry
Changed my rear discs today.
Now I have a wheel speed related clonk on the left rear.
When I brake to a halt the clonk reduces in frequency, it seems to be one clonk per revolution of the wheel.
Nothing apparent when jacked up and spun.
Any ideas?
Many thanks.
Jerry
Mike_V
Have you checked that all of the caliper bolts are tightened correctly?, just a thought to rule that one out.
2004 Red edition in Sable.
alfajerry
Thanks Mike, but yes, went back through the whole procedure.
Jerry
Jerry, when you jacked it up and rotated the hub, was the wheel attached? I was thinking maybe wheel nuts? Maybe something stuck in the tyre?
I know it sounds basic, but just trying to eliminate things.  s;) ;) s;)
Jay67
warped new disc or caliper sticking maybe?
alfajerry
Wheel attached when rotated.
Nothing in tyre.
No indications of sticky caliper.
Discs are Mintex, so hopefully not at fault.
Jerry
The brake hose isn't touching the wheel somewhere is it? I've seen that happen before.
kidkarter
hmmm unusual !! cv joint perhaps ? don't usually make that much noise when they start to go on the back of a car but i'm foxed if there's nothing else obvious !? have you tried checking the disc next to the caliper to see if its warped when you spin it ? it'll be easy to see if something not right ?
good point loadswine ! might be catching a balancing wieght ?
alfajerry
I'll be taking it to bits again tomorrow and I'll come back with more info.
Thanks for suggestions so far.
Jerry
smarty72
Have you checked both sides? I know it's obvious but sometimes it can be really deceptive where the noise is actually coming from.
If it was a problem with a warped disc or simiar that was loud enough to notice I would imagine you would feel it through the pedal.
current: Astral Black FL
Ex: Forest Green 2003.
kidkarter
yeah true too ! though my money is on loadswines brake hose ! explains why it dissapeared when he jacked it up ! the hose tightened   s:wink: :wink: s:wink:
alfajerry
Showed the car to a mechanic friend last night, he gave me a list of things to double check.
Went through them all today and refitted the disc. No change.
Gave up and refitted the old disc.
Problem solved.
The new Mintex disc is faulty.
Now the hassle of sending back and getting a refund.
The last Mintex disc I buy.
Thanks for all your suggestions.
Jerry
Well at least you got to the bottom of it Jerry. Pagid discs are supposed to be decent and someone mentioned a reasonable deal somewhere on here last week.
normanh
I think Pagid are reasonable at Euro car parts, just looked them up for a 2001 £34/front, £43 Rear. Seems reasonable to me.
norman
Steve Green
Can you identify exactly what the problem was?
Useful info for both the supplier and us!
2003 Facelift SMT
Did my old avatar offend you?
alfajerry
Must have been some kind of distortion in the disc leading to pad knock off on every revolution.
Jerry
