front wing removal
Started by wotugonado, April 20, 2012, 14:28
wotugonado
Hi,
Has anybody removed the front wing off their mr2 ? Not happy with mine so either gonna replace or send off to get resprayed. Just wondered if there
are any pointers or hidden bolts/clips i should be aware of.
two on the bottom near the door covered in alot of paint. two on top under the bonnet. and one half way up the wing between the two door bolting points and can only be accessed by moving the whell arch out of the way
wotugonado
Cheers bud, is there anything to connect to the front bumper ?
to remove the wing properly its front bumper off, the headlight next to the wing, the wheel arch and the bolts above to remove it. oh and the last one is the ball ache
wotugonado
Aghhh i thought the first post made it sound too easy, oh well it needs doing, think ill try an source a panel then do a
straight swap rather than doing all that twice.
whats wrong with the panel as a good bodyshop can make it all good still fitted
wotugonado
Yeah thats the problem, looks like a bad body shop got too it first. seems to have had a problem around the indicator at some point,
almost as if some one s pushed to hard when removing/fitting the indicator and damaged wing, has been repaired (by stevie wonder), but in the sunlight cuz i know its there, its glaringly obvious and very annoying.
