torque setting for alloy wheels
Started by alimcfly, April 24, 2012, 15:10
alimcfly
Hi
just bought some wheels for my mr2 and a torque wrench
would i be right in thinking that about 120 would be the correct setting?
AmeR
103 I seem to recall
alimcfly
oh right, in that case i was a bit out then
E
No way, they should only be torqued to 76 lb ft, unless you are using some other scale of course.
Quote from: "E"No way, they should only be torqued to 76 lb ft, unless you are using some other scale of course.
76lb/ft = 103Nm - going to take a stab in the dark and say the OP was talking Nm too (IIRC 120Nm is Ford? 110Nm for common Vauxhall fitments)
E
Quote from: "aaronjb"
Ah! metric muck it will never catch on.
VVT-i
!00% deffo 103NM.
2005 MR2 Roadster  (Black)
alimcfly
103 it is.
 thanks
