Temp Guage Bulb Replacement
Started by Anonymous, May 6, 2012, 20:37
Hi, anyone know how you go about replacing the temp guage bulb please? ALso where can you download a workshop manual?
Thanks,
Jeff
OldMan
The Roadster's gauge cluster is lit with small incandescent bulbs that have been identified as 2723s in various internet postings. I believe that 2721s are the correct replacement for the OEM instrument cluster bulbs.  These are the bulb designations used in the USA.  The designations may be different in the UK.
http://www.bulbtown.com/2722_MINIATU...ASE_p/2721.htm
Green Goblin
And to get to the bulbs:
pull the gauge surrounding towards you (it wil click off)
Then the gauge cluster is mounted with four (if I remember correctly) screws.
[centre]1986 MK1 Sherwood Toning - 2000 MK3 Black
Click here for MK1-keychains - MK2-keychains - MK3-keychains[/centre]
Barney Bear
if you get stuck I have a couple I could send you   s:D :D s:D
54 Sable, Air con, hardtop
