Where should this wire go?
Started by adscan, June 29, 2012, 13:25
adscan
When changing the spark plugs I noticed this wire was loose. It looks like it should be bolted down somewhere. The is a plug at the other end. It is in the centre of the pic.
Anyone have any idea?
Not sure which one I'm meant to be looking at, the one going down from the right of the loom past the O2 sensor plug?
It's not the MAF wire is it?   s:shock: :shock: s:shock:  Do you have a pic of the other end?
adscan
This is the one I am holding. It has a flat metal plate.
It looks like it should be earthed on the block somewhere.
AmeR
It's not an earth but if you pop your plastic cover off and undo the bolts holding the coil pack wiring down, it attaches under the bolt on the side nearest to where it is now.
adscan
Quote from: "AmeR"It's not an earth but if you pop your plastic cover off and undo the bolts holding the coil pack wiring down, it attaches under the bolt on the side nearest to where it is now.
Do you know what it is for?
SteveJ
Quote from: "adscan"
It's an RF noise suppressor
adscan
Will bolt it back on. Many thanks.
AmeR
Just for more info:
adscan
Quote from: "AmeR"Just for more info:
yup..all bolted back on..
thanks for advice.
