toyota front and rear spats
Started by wotugonado, July 25, 2012, 11:01
wotugonado
Right i may have sourced some 2nd hand front and rear toyota spats, problem is they are still attached to the other car.
Couple of questions
what are they made of ?
how are they attached ?
finally any ideas how to remove them without causing damage, as i believe they are quite rare to come across and dont want to wreck them.
Any help is appreciated.
AckersMR2
Does the other owner of the car know you plan to remove them?  s:lol: :lol: s:lol:
My only car is a Ducati
wotugonado
Quote from: "AckersMR2"Does the other owner of the car know you plan to remove them?  s:lol: :lol: s:lol:
  s:lol: :lol: s:lol:   He/she will do by this time tommorrow  s:wink: :wink: s:wink:  Just ironing the stealth balaclava as we speak.
PeteT
Your no where near me are you?
The spats are bonded and bolted on. One of my spats came off the other week (were you doing a test run?   s:? :? s:?  )
On the fronts there is a line of bonding stuff along the top edge and bolts underneath the bumper. I think the rears are just bonded on.
You can see the line of the bonding stuff in this pic that Les so kindly took
Pete
wotugonado
Arrghhh the one that got away  s:D :D s:D
so just undo bolts and lever away gently from away top edge ?
simers
the only way to get the bonding off is to cut it wit a very sharp blade...if the back ones are just bonded on you will probably break them takin them off if they held on with tigerseal...
Mr2 mk3 1.8vvti 01,93 mirage 1.5,94 pulsar 1.3, 00 306 2.0 hdi
If its not broke, don\'t fix it!!!!
The only way forward is sideways!!!! ;)
If the car is the same colour, why not swap bumpers? Just an idea.
wotugonado
Yeah I did give the complete bumper swap idea some thought, but as they're the wrong colour it would probably be just as cost effective to buy new spats, is there no chemical that would help to soften the glue ?
Ive taken body kits off before. Its possible to recover the bits that have been glued on and reuse, but the bits they were glued to are pretty much goosed, particularly if Tigersealed.
If body taped you might be lucky. Heres one I stripped today, which had been taped. Took a couple of hours to get the tape off one panel.
wotugonado
What are the toyota spats made of ? they re very pricy for fibreglass so i presume they re plastic, or are toyota complete rob dogs......................
Quote from: "wotugonado"What are the toyota spats made of ? they re very pricy for fibreglass so i presume they re plastic, or are toyota complete rob dogs......................
Have you seen their prices? Bonkers!
simers
well if they genuine toyota they are probably plastic
Yep plastic same stuff as the bumpers.
wotugonado
Good at least if theyre plastic, they might hold up a bit better to being removed   s:) :) s:)
Even so they re still overpriced new, cheeky toyota rob dogs   s:D :D s:D
Quote from: "wotugonado"Even so they re still overpriced new,
In your opinion, we've had this discussion before.... unless you are willing to make them available to Toyota owners worldwide with all the relevant approvals, paint types, warranties etc for less, then it is only an expression of your financial status, because presumably you don't want to pay what they want.
wotugonado
Ive never had this conversation with anyone before  s:? :? s:?   It is only my opinion but around £600.00 pounds for front and rear very nice looking tiny bits of plastic is exessive, and is i suppose relevant to financial circumstances, im not on the breadline, but i would also like value for money. considering what else that could buy for the car, i believe they are expensive.
simers
Quote from: "wotugonado"Ive never had this conversation with anyone before  s:? :? s:?   It is only my opinion but around £600.00 pounds for front and rear very nice looking tiny bits of plastic is exessive, and is i suppose relevant to financial circumstances, I'm not on the breadline, but i would also like value for money. considering what else that could buy for the car, i believe they are expensive.
If i had a set of these i could get fibreglass copies made off my mate...the hyundai ones i posted in another thread are copies of genuine ones and there is absolutely no difference only they are firbreglass
wotugonado
Getting them in first place is the problem, unless your willing to buy new, 2nd hand they appear quite rare.
simers
Quote from: "wotugonado"Getting them in first place is the problem, unless your willing to buy new, 2nd hand they appear quite rare.
i no yea mate...i was gonna get TTE spats made up off a corolla to suit the MR-S...what would people think of them??
