Rattle from roof clasp
Started by ao30, November 19, 2012, 19:05
no1trancefan
Mine is more wind noise than rattle I jumped on the thread as it mentioned tension adjustment and yeah done my adjustment the right way
jhothersall
Ive moved the hexagon all the way clockwise, but it still rattles will I need to get a new one ?
 m http://s4.postimage.org/yel2jaeal/IMG_4750.jpg m
KV02 XDJ  - 2002 -  Blue - Black Leather Seats - Chrome Pack Installed - Non-working Air Con - Sony Bluetooth Stereo - Owned Since Dec 2012 http://www.mr2roc.org/phpBB3/garage_vehicle.php?mode=view_own_vehicle&CID=270
jhothersall
any ideas ? thank james
dcod
Are you sure it's the clasp? I've had an annoying rattle recently and found it was the sunvisor (when down) tapping against the roof.
jhothersall
Im sure it has to be that, think I need to get a new one
no1trancefan
mine has rattled since i adjusted the clasps but not before.  i only adjusted my clasps as hadnt realised the plastic clip on the window had fell off but if i cover that i dont get any wind noise, stil got to buy a replacement rubber just for that clip grr
ao30
This has come back since last adjusting it about 6 months ago. I have altered it again but over bad road it still rattle sometimes. Problem is, although there's still thread to go, the clap is getting very tough to clip in to place and I don't know how to stop the rattle without tightening it up further and it being almost impossible to fasten that clasp...??  Thanks
Cable ties are your friends here. I have resigned to doing that on mine. Cheap and easy to do.  :-) :-) :-)
ao30
Quote from: "StuC"Cable ties are your friends here. I have resigned to doing that on mine. Cheap and easy to do.  :-) :-) :-)
any chance of a pic or two to see where exactly you've used it/them? Thanks
I'll try and get a piccy when I go to my car in a bit.
Currently she is 10 mins walk away and it's cold outside!!  s:lol: :lol: s:lol:
ao30
Quote from: "StuC"I'll try and get a piccy when I go to my car in a bit.
Thanks looking forward to it. . .
trevsmr2
#36
Quote from: "ao30"
Save your little legs
Thanks Trev   s:oops: :oops: s:oops:    s:oops: :oops: s:oops:    s:oops: :oops: s:oops:
ao30
They hard top clasps? Same applies to the soft top ones on the roof? thanks
trevsmr2
Quote from: "ao30"They hard top clasps? Same applies to the soft top ones on the roof? thanks
Pictured are hardtop yes ,same applies to soft top if needed ,
ao30
#40
Quote from: "trevsmr2"
Great thanks, will try that! What exactly makes the sound-just two bits of plastic tapping when you go  over rough ground?
ao30
no1trancefan
#42
mine is rattling still, still one side, wind noise down to plastic cip coming off driver side, some ppl seem to get no noise without i do above 40mph solution £100 weather strip grr.
re to the clasp rattle i read on spyderforums that one guy took it to a dealer and they sprayed some toyota windstop kit whaterver that is however his was under warranty at the time cost was approx $200 which didnt need to pay, he did comment on the excess grease around the clasp so was wondering if maybe applying grease to the clasp mechanism may help?
Kees
jhothersall
#44
I did replace it what nightmare .... I had to silcon in the handle ... its great now but never again  s:-( :-( s:-(
