removal of rubber exhaust hangers
Started by wotugonado, December 28, 2012, 18:20
wotugonado
Well over the weekend I will be attempting to fit my new rear arb and tte exhaust  s:D :D s:D  can't wait........
Only problem is I cut my hand the other week and still don't have full mobility in my thumb, so with that in mind, what's the easiest way to get the exhaust rubbers off without the proper removal tool ? Any pointers will be greatly received.
A couple of sturdy screwdrivers and lots of silicone lube spray will help. Good luck with it.  s;) ;) s;)
I found a set of these helped.   m http://www.ebay.co.uk/itm/4-PCE-HOOK-AN ... 256ea0a85f m
wotugonado
Thanks guys, i will have a quick mooch round the diy shops tomorrow, and see if i can find something similar.
Jay67
water pump pliers and a bit of spray lube, pop straight off   s:) :) s:)
frogger
There's tools for this process?!? lol
just PULL!   don't even need your thumb, two hooked fingers behind and PULL.
Adding any lubricant will help. Silcone, WD40, Once used a dab of flora margarine, worked a dream.
Jay67
Quote from: "frogger"There's tools for this process?!? lol
we are still on the subject of exhaust hangers aren't we?   s:? :? s:?
frogger
 s:lol: :lol: s:lol:
If we're not, I'd sure as hell leave those screwdrivers, hooks, picks, and pliers alone! Clearly you're all masochists...
wotugonado
Quote from: "frogger"Adding any lubricant will help. Silcone, WD40, Once used a dab of flora margarine, worked a dream
 s:shock: :shock: s:shock:  last tango in paris ?
 s:lol: :lol: s:lol:    s:lol: :lol: s:lol:
