Help...Need a new exhaust ASAP
Started by trickyD, February 9, 2013, 19:19
trickyD
Looks half decent from inside, welding looks nice:
Doesn't appear to be in bad shape apart from the tips (or lack of)
I couldn't see much wrong, heat shield looked well, wasn't sure where the cat joint was mind...
Another pic, looking at silencer:
Was tipping it down so I couldn't take a proper look
- the sound was bearable at low speeds, it's more of a drone at 3k....
Bits for sale!
Well, there is a stock system here if you want it. I can always have a look at the precats if you like. I have no garage though, so might be an idea to wait till the weather improves a bit.
trickyD
Thanks  s:) :) s:)
I will get my mechanic to look and confirm what the issue is first, I'm not convinced its the box now as it looks in reasonable shape...
... I will investigate further and report back!
 s:) :) s:)
Bits for sale!
kentsmudger
Comparing it with mine, in shape it does look a little like the H&S backbox with missing tips - Some owners on here have described theirs as boomy or droning at certain speeds
As has been said, the heat-shields around the standard cat are notorious for rattling, but it is a very metallic rattly, clangy noise, not a drone.
The cat is visible in the pic I posted earlier, it is the lumpy pipe below the chassis bar, between the exhaust tips - From the right of that section, the cat has a pipe that extends towards the engine and then curves upwards through a twin-pipe flexible mesh section (pic below) All of this unit is surrounded by heat shields secured with rust-vulnerable spot welds and the flexi sections can corrode too - a blowing pipe can start off droning
Where are you in Essex? Maybe someone could meet up with you for a look - We have several members over there and I am only 20 miles into Kent from the Dartford tunnel (With an H&S exhaust to compare to yours!)
trickyD
Thanks everyone for all the help and advice - what a great forum this is!  s:) :) s:)
Cheers KentSmudger! I might take you up on that when it stops snowing! :O
Although pretty sure H&S are near festival leisure in Bas which is next to where I used to work, couldn't hurt to drop by?
 s:) :) s:)
Bits for sale!
kentsmudger
That's them - They will be able to tell you if it one of theirs, and their work is of very high quality, but they are not a cheap solution! If it is their work, I do wonder how the tips came to be missing.
I should identify the source of the problem first, then consider your options to remedy - Seems a stock unit would suit you better than a custom job, however well made
trickyD
Well my cars has had the once over and apparently their is no blowing :S
So it must just be bloody noisy. Having said that it will only ever be used round town 10 minutes tops and for weekend razzing! So it hasn't annoyed me since the dreaded 2 hour motorway journey.
 Think I might even miss the noise when opened up, if I went to a standard system?  s:-o :-o s:-o
Lets see how I get on, I need brakes and a new crossmember now >:(
Bits for sale!
MattPerformance
Has it got a cat fitted? (that could explain the amount of noise)? And if not (or not sure) does the engine light work (if so is it on?).
Without wanting to come over as smug... "I need brakes and a new crossmember now..." you do remember me saying that when you buy one of these cars cheap, the price you pay is not what it ends up costing you, right?!  s:) :) s:)
trickyD
Ha ha funny!  s:) :) s:)
It was still a bargain and I love it! None of these little niggles are issues, not like it won't start or anything  s:) :) s:)
Mechanical gave it a good bill of health, only advisories but I like my cars to be perfect you see  s;) ;) s;)
Still, very funny  s:P :P s:P
Bits for sale!
trickyD
Oh and ECL is on, bank 1 or 2 apparently (only had one replaced by dealer, second will be fitted FOC soon).
So...it mite not have a cat I suppose..got 12 months ticket though.
Bits for sale!
MayerT
Did you find out what type of exhaust this was? Very curious!
Two's Company
#36
I have a H&s and it doesn't sound like your descriptions. Louder than stock in a good way - drones a bit at 3k revs on motorway but stay over 3k revs and it is fine.
trickyD
Oops, sorry!
Mechanic assured me its stainless, so maybe a Hayward?
I need to get my arse over to Bas and ask them, maybe they can stick some new pipes on the end as well :S
I hope it is H&S  s:D :D s:D
So long as I don't go on the motorway it's actually nice...
Bits for sale!
Two's Company
You're in luck if it is because a new one is over £500 nowadays. I can't tell from you're pictures. There used to be sound clips on the site if you want to search and compare.
trickyD
Having said all that about H&S, looking at the pic mine appears to drop/slope down towards the front and the Hayward slopes down towards the back of the car. This would make it a different item...
Anyway, I need to resurrect this thread as I did another motorway journey and it has to go!
Anyone in Essex, Herts, south Cambs, south Suffolk (poss North Kent) have a standard unit for sale at a cheap price? I just missed one on eBay for £30, gutted.
If you fancy a track or fun only zorst then I will be selling mine after the swap, though I've kind of stiffed the sale potential with this thread!
 s:) :) s:)
Bits for sale!
I have one here, but guess I'm a bit too far away, in Surrey.
trickyD
#41
Thanks, but I think I'd rather not travel more than 30-40mins
Bits for sale!
Urban
#42
I have a mint standard system in norwich
trickyD
#43
That might be a bit far from me, cheers
1hr 45 minute drive each way.
Thanks though, and I realize this is all making me sound very picky!
(Which I can be)
 s;) ;) s;)
Bits for sale!
maybe you could do a trade with a member who has a standard system and wants a noisy one. I can help with fitting if you needed it.
trickyD
#45
Thanks, that's a great offer  s:) :) s:)
I had kind of hoped to make a couple of pennies on it to pay for my brakes but perhaps I'm dreaming?
Lets see how desperate things get with offers  s:) :) s:)
Bits for sale!
Quote from: "trickyD"Thanks, that's a great offer  s:) :) s:)
Offers are not aloud on here im afraid, best to put up a price with the conditions if your going to look at an exchange.
would help if you knew what it was if your going to sell it
trickyD
#48
Quote from: "rbuckingham"
Offers are not aloud on here I'm afraid, best to put up a price with the conditions if your going to look at an exchange.
The first offer referred to the offer of help fitting it, the second offer refers to offers to me of purchasing an exhaust, of which there have been quite a few. All offers have been out in the open with prices associated. Not sure if you've misread something?
Bits for sale!
trickyD
#49
Quote from: "markiii"would help if you knew what it was if your going to sell it
Indeed, once it's off I can inspect properly.
I'm sure someone will want it...
Bits for sale!
