Water level problem.
Started by Zonda_, February 23, 2013, 14:31
Zonda_
I've been monitoring my water level over the past few days and I can't work out what's going on!  I come in after a drive where the engine is fully warmed up, check the water level and it's barely visible in the header tank. Undo the top of the tank after it's cooled down a bit and the level shoots up to way above High. The temperature gauge never moves higher than half way.  I'm assuming it's an airlock but I've had the car running on the drive with the top off the header tank, watched the level rise to the point of over-flowing and then drop right down again which I assumed would have been the air escaping for the system but it's still the same?
Help!
2001 Roadster, che manifold, 40mm lowering springs, BMC Carbon intake mounted behind battery.
Have a look at the bleeding procedure mentioned here
 l viewtopic.php?f=47&t=20138 l
It may help, particularly if you haven't yet used the bleed point on the front firewall.
Zonda_
Thanks for that, I don't have ramps and our drive is on a slope so I think it'll have to be done when it goes in for its intake mod.
Use the slope of your drive instead of ramps, perhaps. I do that with mine. Its just a matter of making one end of the car higher than the other really.  s;) ;) s;)
Zonda_
Will give it a try tomorrow if the weather warms up, don't want the snow topping up the tank while I'm working!
dj2k21
Just leave the car running and undo the tap on the front mate, sorted. Me and tom did mine woth me having 2 radiators
Sent from my GT-I9300 using Tapatalk 2
Zonda_
I'll have to have a look for the tap tomorrow, never seen it!
dj2k21
You will need to remove the plastics from the front mate. Very easy just push the middle of those plastic clips in and they pop out. The tap is on the firewall with about a foot of clear hose attached tp ot coiled up. Just turn the tap and the water will start to come out.  Once u dont see any air bubbles anymore u know its done. Remember ur going to need to keep pouring water in the tank in the engine bay as ur doing it so u dont empty the system of water
kentsmudger
Tap is here -
kentsmudger
Quote from: "dj2k21"You will need to remove the plastics from the front mate. Very easy just push the middle of those plastic clips in and they pop out. The tap is on the firewall with about a foot of clear hose attached tp ot coiled up. Just turn the tap and the COOLANT will start to come out.  Once u dont see any air bubbles anymore u know its done. Remember your going to need to keep pouring COOLANT in the tank in the engine bay as your doing it so u dont empty the system of COOLANT
Don't use water in there!
dj2k21
As long as its got some anti freeze in there, there is no reason at all u cant put water in there. Ive never had a single issue at all using water. As said 100% water is a no no but im usually a 50/50 mix. Im pretty sure the op isnt that nieve to only use water really.
