whiteline rear droplinks advice
Started by belspyder, March 2, 2013, 13:26
belspyder
hi all,
i was looking for some universal whiteline rear droplinks, i've seen the ones vvt-i has but they are no longer produced serial nbr was whiteline klc40-195.
A company in holland stocks white line stuff & they offered  2 types which are the same dimensions as the old ones
 m http://www.fineline-imports.nl/whitelin ... 68809.html m
 m http://www.fineline-imports.nl/whitelin ... 68833.html m
on the website from whiteline you can see there's a version with a 10mm stud & with a 12mm stud
 m http://www.whiteline.com.au/docs/bullet ... BL-290.pdf m
does anybody know which stud size i need for my 2?
thanks
Krissg
i spoke to whiteline just last week about this, they dont make them anymore but if you give them the dimensions they will supply them, only iss is the stud size is 8mm on the 2 and the smallest they cann supply with a 200mm bar is 10mm.
options are to either bore your ARB hole to 10mm or urgrade the ARB while your at it, choice is yours!
2003 MR2 Red....watch this space!
Ex- MR2, black MSD kit.
belspyder
thanks that's a quick reply   s:D :D s:D
i intend to order  to front & rear whiteline arb toghether with new rear droplinks, so it would be safe to buy the new model klc 140-195 with a 10mm stud?. or will i not fit the shock?
Krissg
when I spoke to whitening I think they said it's 165-210mm but at 195mm I'm sure you'd be fine.
you can get whatever stud size u wish now as long as they marry up.  s:) :) s:)
