Engine management light help
Started by Zonda_, April 17, 2013, 14:11
Zonda_
I've just discovered that my engine light is not functioning and I'm pretty sure of the reason.  I've just put my OBD tester on the car and it shows up the common Po135 sensor issue.  I'm assuming rather that fix the fault the garage have just bypassed the light or something.  A search on here has revealed nothing, how can I get my light working again?
2001 Roadster, che manifold, 40mm lowering springs, BMC Carbon intake mounted behind battery.
dj2k21
Replace the bulb? Lol oufff schoolboy error that zonda, how many times have we seen to check the light on threads giving buying advise to newbies lol.  Luckily for you the clocks are a 2 min job to remove to check the bulb, its either a bulb removal or a resistor of some description fitted to it. Are u sure the light isnt working and it's just not an old fault stored on the ecu?
You need yo remove and dismantle the instrument panel. Don't worry though it's really not that difficult. Drop the steering wheel to its lowest position, grab the binacle and pull. There are three Philips head screws and some plugs around the back of the cluster. Then you need to free the front off it and check the eml. Sometimes it's as simple as a bit of tape, blutack or gum over the led. Sometimes it's more sinister and the led has been broken on the circuit board.
You can replace if you have soldering skills. Any garage that does this are scumbags in my opinion, and now a non functioning eml is an automatic mot failure.
Quote from: "dj2k21"its either a bulb removal or a resistor of some description fitted to it
Or some black electrical tape over it  s:) :) s:)
dj2k21
Quote from: "onion86"
Haha true. Silly me for asuming people that do this kind of thing have any kind of mechanical knowledge, thanks onion  s:) :) s:)  lol
Zonda_
Will have a look tomorrow. I swapped the clocks in my Soarer and that was a sod of a job so this sounds a doddle! Are there any pics of the light so I know what I'm looking for?
Zonda_
Ok so I've got all the clocks out and dismantled but there is no sign of any foul play! The eml bulb is in place and nothing has been tampered with.  How can I test the bulb?
ChrisGB
Quote from: "Zonda_"Ok so I've got all the clocks out and dismantled but there is no sign of any foul play! The eml bulb is in place and nothing has been tampered with.  How can I test the bulb?
It should come on when the ignition is switched on, then go off after the ecu does its checks or when the car is running.
Chris
Zonda_
Quote from: "ChrisGB"
Chris
Ok, so it's doesn't light at all, can the bulbs be replaced and if so how and where do I get one from?
It isn't a bulb, it's an led mounted on the circuit board.
dj2k21
As wabbit says. U need to heat the solder up and remove the led. Then replace with one from maplins. About 5-10p each
Zonda_
Just took it to my local garage who also do my MOT's they said engine management light is not covered on the MOT so it can wait. I'm not messing with solder!
Did you look close enough to see whether someone had stuck something into the LED, if you thought it was a bulb maybe you weren't looking at the right one?
Zonda_
No, it was the right one and looked identical to the two either side of it.
I suppose it's quite possible that it's burned out, never seen one not work unless it had been doctored. Might be worth getting a multimeter on to see if it's actually getting any voltage. No huge emergency now you have your obdii reader  s;-) ;-) s;-)
wotugonado
Tosspots !! the ass wipe who i bought mine off, chiselled the eml off the board and just for good measure took the low fuel light with it, i think ive got a spare led if you do decide to change it. pm if your interested.
tomaky
Picture may help the boys, soldering really is a doddle  s:) :) s:)
Westfield Seiw
Ex - 2005 Porsche Cayman S
Ex - 2003 Sable
Ex 2004 Blue  Roadster RIP
