Odd tyre wear.
Started by Zonda_, April 23, 2013, 11:08
Zonda_
Whilst washing the car a couple of days back I noticed that the inside shoulder of the left rear was bald! I had a camber and tracking alignment done when I put the new (Toyos) on and another one done when I had the lowering springs fitted. The printouts show that everything was ok after this. I run the pressures people recommended on here and check them regularly. The right rear is ok.
2001 Roadster, che manifold, 40mm lowering springs, BMC Carbon intake mounted behind battery.
tomaky
Guessing that its a gradual wear from inside to out?
Westfield Seiw
Ex - 2005 Porsche Cayman S
Ex - 2003 Sable
Ex 2004 Blue  Roadster RIP
Zonda_
No, first inch of the tyre edge is completely bald, the rest of the tyre is worn but not to the same extent. The groves on the tyre are completely gone yet still perfectly fine on the other tyre.
tomaky
Very strange, pickled me all i can think of is being there when tyre went on or foul play by someone which sounds to me implausible.
Westfield Seiw
Ex - 2003 Sable
dj2k21
When I had a rear left wearing it turned I changed the rear trailing arm bushes and it seemed to fix the problem.  It also fixed the ever so slight wobble I wss getting on boost from the back end
