Wing mirror removal
Started by Maverikk, May 28, 2013, 20:02
Maverikk
Searched for this in the tool bar but could not find any relevant threads.
I am having my wing mirrors wrapped next week and will need to detach them in order to do so. How easy a job is it? It can be done with them installed, but the finish will be better with them off.
Any tips? Thanks.
Mav
Take the door card off, thend it's two 10mm nuts and one plug under the dash. Getting the wire back in can be a royal pita!
Maverikk
Doesn't sound too tricky. (He says...)   s:) :) s:)
You should see if UKtotty has any heated mirror kits left.
You are doing all the work necessary to add them, you might as well have a bonus of heated mirrors too!   s8) 8) s8)    s8) 8) s8)
Maverikk
They sound good, but more for a winter mod!  s:) :) s:)
From experience it is much better to do it in the warm. Panel edges hurt more when you are cold!!  s:shock: :shock: s:shock:
