mystery connector in engine bay
Started by wizzard1983, June 11, 2013, 17:11
wizzard1983
Hi All,
Whilst topping up my oil i found a connector that wasn't connected to anything. it is a black and red wire that comes from the main wire loom. this went into a connector and the other end of the connector was a bit of metal that looked like it had been broken off something.
 Please help me  identify what this is for and if i need to get the car looked at by a garage.
Thanks for your help.
wizzard1983
P.S How do i put a pic on the post to help? lol (sorry)
Markb
Quote from: "wizzard1983"P.S How do i put a pic on the post to help? lol (sorry)
Open a photobucket account..its free to use..upload your pic to photobucket......when uploaded copy the last link in the list of four....paste it on to your message on here.
I noticed a connector up behind the dipstick area whilst under mine doing the oil filter the other day.....i guess its for cars with air con or some other extra.
wizzard1983
It was the other side of the engine bay and i have air con. Thanks for the help with the pic upload
wizzard1983
minimike
Can't remember for sure but when I changed the plugs on mine I 'found' the same bit. The bracket had snapped just like yours. If you take the plastic engine cover off you will probably find the other end still under a bolt?
I just used a tie wrap to keep it out of the way.
2006 red, 2006 silver TF212, 2003 black, 2001 black
wizzard1983
thanks for the reply, did you find ot what it is for?
Looks like it has snapped off, remove the cover and you should see where from  l viewtopic.php?f=11&t=42802 l
fretlessfender
That's the one - it locates under one of the 12 mm(?) bolts going through the lh end of the cam cover (under the plastic).
Underbody bracing, Maxbore TB, Pipercross filter, Pre-cats gone, solid gearchange bushes, Focal A165s + Genesis Profile 2 amp + Eonon head unit, which sort of does everything it claims to but not as well as it should.... Red, 2000, hardtop in the garage for the summer. \":-)\"
The mystery thing is the car's noise suppressor - part of the ignition circuitry. It has a single wire feed earthed to the block by the bracket. If it isn't earthed it won't be doing anything. Not a huge problem unless your coil packs are creating excessive radio interference.
wizzard1983
Thanks for all your replies. I will take a good look under the engine cover asap.
