Had my TTE turbo on the dyno + boost readings
Started by stargazer30, June 17, 2013, 15:34
stargazer30
Update - Well after getting to the bottom of the recent ECU light and codes, the car has had 2 x new o2 sensors and a new MAF, still feels lacking a bit though.
So today I fitted an electronic boost gauge to check the turbo pressure.  I was expecting it to be low but no, its reading 9 to 10 PSI on full throttle right up the rev range.   I did catch it pull boost down once to 8psi over 6000 rpm, not sure if the TTE map does that by design or if it was a glitch.
So I guess that rules out the turbo, I'm amazed its struggling to hit 175lbs/ft at 10 PSI boost.
ChrisGB
Compression test the engine? Check timing trims to see if ecu  is pulling timing?
 Chris
stargazer30
Quote from: "ChrisGB"Compression test the engine? Check timing trims to see if ecu  is pulling timing?
 Chris
The engine is pretty fresh at just over 30,000 miles and it made stock power 135bhp before the turbo went on so I dont think compression is the issue but if all else fails I will check it.
I'm tempted after reading an old thread on Liz's TTE to get the boost turned down.  Liz's was low on power and was set at 10psi.  I do recall the correct boost level is 7psi.  I do think the ECU is backing things right off due to the high boost level.  Its just a theory though, I don't know enough about this stuff to be sure.
Cairo
I might be wrong, but i´ve always been under the impression that the TTE turbokit is supposed to run at 0,35 bar which translates to about 5 psi. If this is unclear, i could always check my papers.
Mr2 TTE Turbo
stupink
Im *VERY* supprised everyone seems happy about that graph????  Am i looking at a different graph to everyone else? lol.
the power comes to a dead stop at only 5k and thats just not right at all. it should continue to pull cleanly up untill past 6.5k and thats why the power is down.
as the OP has posted boost pressures since are holding, then id say ignition is going.. possibly det from it being lean and the ecu cutting back? have you monitored it for detonation at all? it could also be air temps, what charge cooling is there? was there a fan on any intercoolers??
as above lambdas make no difference at full throttle.
What ECU is controlling the fueling and ignition? was it mapped on this car or another and transferred?
It's certainly not the best graph I've ever seen. The torque curve is a bit messy and seems to hit some kind of limiter.
Does the TTE kit have some form of MAP sensor? (I'm guessing yes)
This seems very similar to an issue I was having in my car when it was hitting the max threshold on my MAP sensor. It pulled back the boost, then pushed it up, hit the limiter, pulled it back etc etc etc.
In my case a hard limit on the MAP and a too-aggressive mapping on the ecu
Sounds like it's pulling timing, if the boost is strong but power is not.
I'd get your AFR checked as well.
stupink
there is an afr graph posted below the power run, while leaner than sane in my opinion it does seem to be smooth, suggesting a timing ajustment rather than cut or fuel cut. else the AFR's would "lean out" relatively.
so on these engines, i guess thats got to be intake temp, water temp, or det? (which i'd expect to see spikes in afr). so im leaning towards intake...  so makes me wonder what intercooling is on this car still and did they put a fan to it.... any info?
Have the injectors been checked for flow etc. As the stock injector is running at max to make what the op is wanting to see in power. The PE turbo is a similar power output and they run stock injectors but with a increased fuel pressure so the injectors are not being maxed.
stargazer30
Been on holiday   s:D :D s:D    So back to business with the turbo.  The posts about the graph maxing out at 5K, thats by design.  The TTET kit uses a sealed read only map designed for the stock exhaust, cat and injectors and to keep the toyota warrenty.  So by design it pulls timing, power,etc..  the lot at 5k.  It does run a MAP sensor too but I don't think it can control boost, just monitor it and adjust fueling to match.
I am planning to turn down the boost by adjusting the actuator, nothing drastic, say 3 PSI so its at 7, then let the ECU re-adjust and see what it does.  Really for the setup I have we should be seeing 200lb/ft peak torque and 190+ BHP at 5K rpm.
stupink
I can't see toyota allowing a car to be sold with a graph that shape.  got any detailed information on the TTE setup i can read through so I can understand the setup better??
stargazer30
#36
Quote from: "stupink"I can't see toyota allowing a car to be sold with a graph that shape.  got any detailed information on the TTE setup i can read through so I can understand the setup better??
They did,here the link to the origonal TTET fitted in the UK by Silverstone performance. Checkout the dyno plot.
http://www.pistonheads.com/roadtests/doc.asp?c=47&i=14678
stargazer30
Well I'm stuffed, the boost can't be adjusted   s:cry: :cry: s:cry:
I had the actuator off the car today, the bar is set at its shortest possible length and the part thats supposed the turn is well and truely seized. I tried penetrating oil and even a little heat but its not going to shift.  The only way I'm going to adjust that is buy a new actuator   s:evil: :evil: s:evil:
stupink
post me a pic of the actuator setup, theres always a way  s:) :) s:)
i've just had a quick look at the graph in that link, very supprised but yup you're spot on.. could be caused by physical restriction in the exhaust/turbo/manifold anything... or could be deliberate cut, what ecu is on it??  not sure how it could achieve a power cut so smooth like that.   i will have a good read up for you mate and let you know my thoughts after some research  s:) :) s:)
stupink
just an addition, looking at your graph, the only points that match the one you posted are pre boost, everything after shows 20hp higher at any given point very linear across the entire graph, this leads me to believe your boost is simply lower than the one in the other graph.  where do you have your boost guage plumbed into?  don't forget restrictions in the intake system reduce pressure, so if it is at the turbo compressor, you may have a few psi less at the inlet. less boost is less power out and out. my earlier observations were skewed by the fact i was not aware the mapper deliberately made that shape so ignore them all.
also be aware that boost guages are crap,especially at these pressure levels which really are quite minimal, so difference from one guage to another may also mean you think you're running more than you are. I once put four of my boost guages i had laying around on a pipe and put a foot pump on it, only two guages showed the same figure, one i think faulty was £180, so money doesnt even mean it works  s:( :( s:(  . for accuracy try to get at least three guages and put them on the same pressure line and only trust the guage that shows the same figure as another.  so my next step personally would be to get a reliable guage plumbed into the inlet directly, and tbh buy a new actuator, if yours is that siezed its probably knackered anyway and could be weak.. what actuator is on it? is it just a garrett? just get the same part number version and put a heat shield over it this time so it doesnt corrode or die  s:) :) s:)   If its a typical garrett type, then tweaking the actuator a bit here or there really wont make much difference if any.. the chamber on them is sooo big that a bit of pressure just opens them reguardless of spring tension.. so you probably just have a weak actuator, you could test this with a foot pump and see what pressure it opens at and compare it to a known good one (or just look online for the figures from others as it should be easy to find)
stargazer30
#40
Heres the actuator before it came off
The dark bar with the nut welded on the end is supposed to turn on the metal rod I suspect. But mine is well seized. It doesn't help theres nothing on the other side to get a spanner on, pilars just chew up the metal rod.
Oh The ECU is a toyota piggy back.  It has its own loom that plugs into the stock ECU.  The MAP sensor is part of that piggy back ECU.  My boost gauge is an electronic one so I have connected its MAP sensor at the same point as the TTE sensor on a very short piece of boost pipe and T piece.  The majority of the run to the boost gauge is electrical wire.
EDIT - the boost feed for both my gauge and the TTE MAP is taken at the throttle body by the look of it.  So its after all the pipe work and intercooler.  So the pressure reading should be correct (assuming the gauge is accurate).  The actuator is fine too, it moves okay under pressure by hand.
stupink
#41
My SPA electrical always showed some funny figures, never did trust it. go on ebay pickup a five pound mechanical one to verify it reads okay or test it against another known device if possible.
meanwhile i would be definitely getting a footpump on that actuator see when it opens (on car is fine). again i woudlnt trust the pumps guage, just pop a boost guage inline.    what models the actutor? i have a couple here that look similar so i could test opening pressures on them once you get a figure if they are the same.
stupink
#42
Quote from: "stargazer30"The actuator is fine too, it moves okay under pressure by hand.
The actuator strength is the boost control on this kind of setup, knowing it holds the wastegate shut is good, knowing its not siezed is good, but does not confirm the actuator is fine.  if the internal diaphram has become leaky, or the internal spring weakened, then it will create less boost than a new item because it will open at a lower psi  s:) :) s:)
on some actuators the spring pretension ajustment makes a difference to the boost because the spring is so much stronger than the force of the actuator, on these types the actuator is so strong that adding pretension is kinda like adding one more strand of cotton thread when trying to hold back an elephant. even adding a helper spring wont make a difference barely, the ajustment arm is normally there simply to ensure the right length so the wastegate is held shut  s:) :) s:)
the pressure you pump into the actutor before it opens is directly the boost it will run, so you can find that with a footpump.
you could save pennies trying a new one by using other methods like manual boost controlers, these stop the boost getting to the actuator early on, so hold it shut longer, meaning you boost earlier as the wastegate wont creep early on, you can also use them to raise the boost level if you so desire.  cheap enough on ebay.
