2 2zz's
Started by p3t3, June 28, 2013, 16:26
p3t3
Well one just wasnt enough so I just picked up another one (+ it was really cheap)  s:P :P s:P
Thought id stick some pictures up to compare the cam side of the engine.
The 2zz in the mr2 now has got +140k miles on it and looks like this..
Quite clean considering age and milage   s:D :D s:D
Then the one I picked up has got 70k on it but looks like this
The lower milage engine is BLACK!!! Loads of sludge in there too!!  s:shock: :shock: s:shock:
First thing on the rebuild is to get those valve seals changed over. + Is this looking like a poorly serviced engine?
Lift bolts looking a bit sorry for them selves but atleast these came out in one piece   s:bounce: :bounce: s:bounce:
What have other people found under the lid on there engines? milage?
Any landing you walk away from is a good one!
Sepp
Any oil change and oil type histories?
p3t3
No unfortunately not. I did drain it last night and im still unsure as to what came out, it was ether bitumen or very old oil    s:crazyeyes: :crazyeyes: s:crazyeyes:
