2zz Head Part Help
Started by p3t3, July 4, 2013, 20:36
p3t3
Is anyone out there really familiar with the 2zz head? or maybe the 1zz if it shares the same part?
I started stripping it down today and as I lifted it off the block and spun it round to look at the valves this washer/spacer fell out and I cant seem to find where it should go   s:? :? s:?
Only place i can sort of assume it should go is where the cam position sensor should sit but im not convinced
Any landing you walk away from is a good one!
Are all of the washers on the headbolts, that's if im remembering correctly.
p3t3
Interesting... Thats the first place I looked and i was surprised the head bolts would clamp streight down on the ally head. They do fit pretty perfect on the head bolt and in the head but... If thats where its come from it means this engine was put together with only 1 of these washers and not x10  s:shock: :shock: s:shock:    s:? :? s:?   (It had an head gasket change not long ago).
Can anyone confirm that the head bolts DO have these washers on them?
like this...
redarrow
I went to ebay and looked up a head bolt set
And there no washers in the kit for the head bolts
Also your notice the head bolts there self got
The washer built to the nut on top.
I have never seen any head bolts that you
Use washers on then insert the head bolt.
[size=85]These are the dreaded code your get with cheap 02 sensors.
P0135 drivers side position. (o2 sensor heater malfunction (bank 1 sensor 1)
P0155 passengers side position. (o2 sensor heater malfunction (bank 2 sensor 1)
P0141 passengers side down below exhaust position. (o2 sensor heater malfunction (bank 1 sensor 2[/size]
