Replacement MAF fitted
Started by wilko59, July 18, 2013, 13:28
wilko59
Cleaned my old air flow meter but seems it was beyond redemption. Finally got around to fitting a replacement which was from a Yaris, what a difference now much more responsive easier to change gear smoothly without riding the clutch. I don't know how I coped for so long. Anyway original Toyota MAFs new seem really expensive, I managed to get an almost new Yaris MAF for £20 delivered. Consisting a can of electrical cleanerfromhalfords costs about £6 if I recall,  it hardly seems worth the hassle
Dave
Red Edition -  Widermuller\'s bling, short shifter, ultimate gear linkages and billet cage mounts.  Garage59 manifold, Proflow quad exhaust and sports cat.  Kenwood/Garmin DNX.
Previous - PFL Blue H/Top & MRs Black 2zz
stargazer30
You've done well.  I'm in the same boat as my MAF was suspect.
£40 second hand from a scrappy was the best I could find, might be junk.   £160 new from Mr T   s:shock: :shock: s:shock:  Or £40 for a non OEM one from Ebay.  I tried the later but so far its not looking good.
trickyD
Good tip Dave, do you have the part number or engine spec which it came off?
Bits for sale!
wilko59
Afraid I dont hknow the engine spec, I can get the code number from the MAF unit but it will read the same as your own on the first two lines, there is a shorter code on the third/last line which is different so I assume it is unrelated to the workings etc.
