Pluming
Started by Vietts, August 20, 2013, 13:14
Vietts
Hey guys I'm doing the 2zz conversion but need help as all my photos got deleted on my phone  s:( :( s:(
Can anyone tell me where these go?
On a 1zz it normally connects to a pipe in the manifold just after the throttle body and the charcoal cannister.
There should be two take off's from the intake manifold, one for the brake servo and one for the vsv.
Probably very similar on the 2zz
Vietts
Just to clear it up for me
picture 1 connect to the throttle body and the other side is for the canister?
And
Picture 2 goes to the inlet manifold?
Could you take some pictures for me? I learn more through pictures :s
If only you had asked for pictures when I had the engine out of the car!
Picture 1 yes, the pipe that comes off the valve in the same direction as the plug connected to the intake manifold, the other pipe connects to the canister.
Picture 2 just connects to the intake manifold.
You're going to have to figure the rest out yourself, if you're fitting a new engine then you should probably already have an idea of how everything is connected.
Vietts
Smashing! Thanks  s:D :D s:D  that was the final puzzle
Just need to do the exhaust then its all system GO!
