Had a oil leak sharing my research
Started by redarrow, August 21, 2013, 03:11
redarrow
Copy from my mot post.
Thank you all was very worried the mot said
Oil leak and yes after full help from members above
I found my problems
This is a video of a common oil leak it
Behind the drivers seat in the engine boot
Just below your dipstick.
My video i just took with oil showing
 m http://instagram.com/p/dQdCz1vaEz/ m
To replace the o ring then follow this guide
 m http://spyderchat.com/forums/showthread ... ioner-Seal m
Correct o ring needed.
9030122013
I found the whole chain tensinar on ebay here
http://bit.ly/1aqxAGy
[size=85]These are the dreaded code your get with cheap 02 sensors.
P0135 drivers side position. (o2 sensor heater malfunction (bank 1 sensor 1)
P0155 passengers side position. (o2 sensor heater malfunction (bank 2 sensor 1)
P0141 passengers side down below exhaust position. (o2 sensor heater malfunction (bank 1 sensor 2[/size]
